Forum: help
Monitor Forum | | RE: FFTW and MPTK: enable multithreading [ Reply ] By: Andrew Gardner on 2008-05-20 18:43 | [forum:62112] |
Two pieces I omitted: (1) need to edit the environment variable. On Mac OSX it's best to edit ~/.MacOSX/environment.plist to add a key-value pair MPTK_CONFIG_FILENAME="/Users/your-username/.mptk/path.xml" (2) I notice that mpd_multithread sometimes exits with Bus Error, but appears to correctly produce the book prior to exit. |
| RE: FFTW and MPTK: enable multithreading [ Reply ] By: Andrew Gardner on 2008-05-06 04:37 | [forum:53949] |
| Finally got to spend some time on this and I have a successful Leopard install. (1) Build FFTW with multithreading (--enable-threads); (2) configure and build MPTK for multithreading, (3) create ~/.mptk and copy the ~mptk/bin/path.xml file there. | |
| FFTW and MPTK: enable multithreading [ Reply ] By: Andrew Gardner on 2008-03-29 02:04 | [forum:22441] |
I am building MPTK for Mac OSX (Leopard), and I notice that FFTW supports a configuration option for multithreading to leverage SMP architectures. I would like to compile FFTW with multithreading enabled, but I don't want to have to make extensive changes to MPTK source to make the two work. Does anyone know if MPTK will build correctly against a multithreaded FFTW? Thanks! Andy |
