Forum: help
Monitor Forum | | mpf.m [ Reply ] By: Clothilde Melot on 2008-02-19 15:34 | [forum:9519] |
Dear Remi Here is a rather strange bug: the option -l of the function mpf is working in a terminal using the "normal" MPTK but the Matlab function mpf.m seems to have a bug. If you find any explanation...!! But anyway this is not such a big deal since one of the two functions is working. Below are the several messages (the one after typing in a terminal and the error message in Matlab). with best Clothilde 1.in a terminal: /usr/local/MPTK-0.5.4/bin/mpf -l "[1:1000]" Bclass.bin Bclasslength.bin ; mptk DEBUG -- MP_Msg_Server_c -- Entering the messaging server constructor. mptk DEBUG -- MP_Msg_Server_c -- Exiting the messaging server constructor. mptk DEBUG -- MPTK_Env_c::environment() - Load successfully the following Block type: mptk DEBUG -- MPTK_Env_c::environment() - harmonic block. mptk DEBUG -- MPTK_Env_c::environment() - chirp block. mptk DEBUG -- MPTK_Env_c::environment() - mclt block. mptk DEBUG -- MPTK_Env_c::environment() - gabor block. mptk DEBUG -- MPTK_Env_c::environment() - mdst block. mptk DEBUG -- MPTK_Env_c::environment() - constant block. mptk DEBUG -- MPTK_Env_c::environment() - anywavehilbert block. mptk DEBUG -- MPTK_Env_c::environment() - dirac block. mptk DEBUG -- MPTK_Env_c::environment() - nyquist block. mptk DEBUG -- MPTK_Env_c::environment() - mdct block. mptk DEBUG -- MPTK_Env_c::environment() - anywave block. mptk ERROR -- MP_FFT_Interface_c::init_fft_library_config() - fftw wisdom file with path /usr/local/MPTK-0.5.4/bin/default_fftw_wisdom_file doesn't exist . mptk DEBUG -- MPTK_Env_c::environment() - No fftw Plan well formed was found. mpf DEBUG -- Parsed interval [1:1000]: min=1 max=1000 includeMin=1 includeMax=1 negate=0 mpf DEBUG -- When exiting getopt, optind is [3]. mpf DEBUG -- (argc is [5].) mpf DEBUG -- Read input book file name [Bclass.bin]. mpf DEBUG -- Read output bookYes file name [Bclasslength.bin]. mpf msg -- Out of the [28] original atoms, [12] atoms satisfy the required properties. mpf msg -- Out of the [28] original atoms, [16] atoms DO NOT satisfy the required properties. mptk DEBUG -- MP_Book_c::~MP_Book_c() - Deleting book... mptk DEBUG -- MP_Book_c::~MP_Book_c() - Done. mptk DEBUG -- MPTK_Env_c::release_environnement() - The fftw Plan is not saved. mptk DEBUG -- ~MP_Msg_Server_c -- Entering the messaging server destructor. mptk DEBUG -- ~MP_Msg_Server_c -- Exiting the messaging server destructor. 2.using Matlab Bclasslength= mpf(Bclass,'l','"[1:1000]"'); Warning: This file is no longer maintained > In bookwrite at 23 In mpf at 23 mystring = setenv LD_LIBRARY_PATH /usr/local/MPTK-0.5.4/lib;/usr/local/MPTK-0.5.4/bin/mpf tempbook.bin -l "[1:1000]" -L "[1:1000]" tempyes.bin tempno.bin mptk DEBUG -- MP_Msg_Server_c -- Entering the messaging server constructor. mptk DEBUG -- MP_Msg_Server_c -- Exiting the messaging server constructor. mptk DEBUG -- MPTK_Env_c::environment() - Load successfully the following Block type: mptk DEBUG -- MPTK_Env_c::environment() - harmonic block. mptk DEBUG -- MPTK_Env_c::environment() - chirp block. mptk DEBUG -- MPTK_Env_c::environment() - mclt block. mptk DEBUG -- MPTK_Env_c::environment() - gabor block. mptk DEBUG -- MPTK_Env_c::environment() - mdst block. mptk DEBUG -- MPTK_Env_c::environment() - constant block. mptk DEBUG -- MPTK_Env_c::environment() - anywavehilbert block. mptk DEBUG -- MPTK_Env_c::environment() - dirac block. mptk DEBUG -- MPTK_Env_c::environment() - nyquist block. mptk DEBUG -- MPTK_Env_c::environment() - mdct block. mptk DEBUG -- MPTK_Env_c::environment() - anywave block. mptk ERROR -- MP_FFT_Interface_c::init_fft_library_config() - fftw wisdom file with path /usr/local/MPTK-0.5.4/bin/default_fftw_wisdom_file doesn't exist . mptk DEBUG -- MPTK_Env_c::environment() - No fftw Plan well formed was found. mpf DEBUG -- Parsed interval [1:1000]: min=1 max=1000 includeMin=1 includeMax=1 negate=0 mpf DEBUG -- Parsed interval [1:1000]: min=1 max=1000 includeMin=1 includeMax=1 negate=0 mpf DEBUG -- When exiting getopt, optind is [5]. mpf DEBUG -- (argc is [8].) mpf DEBUG -- Read input book file name [tempbook.bin]. mpf DEBUG -- Read output bookYes file name [tempyes.bin]. mpf DEBUG -- Read output bookNo file name [tempno.bin]. mpf error -- Choose either one of --length=/-l or --Length=/-l. mpf error -- Please check the syntax of your command line. (Use --help to get some help.) ans = 1 Warning: This file is no longer maintained > In bookread at 25 In mpf at 26 ??? Error using ==> bookread Can't open file [tempyes.bin] Error in ==> mpf at 26 varargout{1} = bookread('tempyes.bin'); |
