Forum: help
Monitor Forum | | RE: Thank you ! It is computing !!1 [ Reply ] By: Rémi Gribonval on 2008-02-14 22:25 | [forum:8793] |
If the debug mode is on, the computation can be much longer. Try recompiling MPTK with the debug mode off for shorter computations. Rémi. |
| Thank you ! It is computing !!1 [ Reply ] By: Clothilde Melot on 2008-02-14 14:32 | [forum:8783] |
Dear Remi thank you very much for your help. It is now computing. Just I have no idea how long the computation should be. Anyway thank you once again with best Clothilde |
