Forum: help
Monitor Forum | | RE: fftwisdom file seems to appear again ! [ Reply ] By: Rémi Gribonval on 2008-02-08 11:49 | [forum:8223] |
First of all, don't worry about the fftw_wisdom stuff. This appears as an error but should indeed just be a warning, since it does not prevent MPTK from functioning but can just slightly slow it down at startup. Supposedly, if you relaunch the very same command a second time there should not be any such message. Please let us know. Now to the error mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error while loading the dictionary file [/home/melot/matlab/Matching_pursuit/default.xml]. mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error ID: 7 . mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error description: Error reading Attributes. This indicates that there was an error parsing the XML file, and it is only logical that MPTK aborts. I don't quite understand what is the problem here. It may help if you post the results of the unix commands 'ls /home/melot/matlab/Matching_pursuit/' as well as 'file /home/melot/matlab/Matching_pursuit/default.xml' and 'less /home/melot/matlab/Matching_pursuit/default.xml' Best regards, Remi. |
| fftwisdom file seems to appear again ! [ Reply ] By: Clothilde Melot on 2008-02-08 10:53 | [forum:8221] |
Thank you very much for your answer Remi !! Here is the story. I did adress the MPTK_CONFIG_FILENAME variable. Then I discover that I hadn't the "reference" directory but I reload all the packages and I copy dic_gabor_two_scales.xml as a default.xml file. I took care of giving the right path when I launched the InstallMat2MPTK script again. I get the following error message. Can you help me again ? thank you so much by advance !!! cheers Clothilde InstallMat2MPTK Enter MPTK Path ['/usr/local/bin/']: ['/usr/local/MPTK-0.5.4/bin/'] Enter Dictionaries Path ['/home/melot/matlab/Matching_pursuit/Dict/']: ['/home/melot/matlab/Matching_pursuit/'] >> Mat2MPTKdemo mptk DEBUG -- MP_Msg_Server_c -- Entering the messaging server constructor. mptk DEBUG -- MP_Msg_Server_c -- Exiting the messaging server constructor. mptk DEBUG -- mpd - switch -D : optarg is [/home/melot/matlab/Matching_pursuit/default.xml]. mptk DEBUG -- mpd - Read dictionary file name [/home/melot/matlab/Matching_pursuit/default.xml]. mptk DEBUG -- mpd - switch -n : optarg is [1000]. mptk DEBUG -- mpd - Read numIter [1000]. mptk DEBUG -- mpd - switch -E : optarg is [tempdecay.txt]. mptk DEBUG -- mpd - Read decay file name [tempdecay.txt]. mptk DEBUG -- mpd - switch -R : optarg is [100]. mptk DEBUG -- mpd - Read report hit [100]. mptk DEBUG -- mpd - When exiting getopt, optind is [5]. mptk DEBUG -- mpd - (argc is [8].) mptk DEBUG -- mpd - Read sound file name [tempin.wav]. mptk DEBUG -- mpd - Read book file name [tempbook.bin]. mptk DEBUG -- mpd - Read residual file name [tempres.wav]. mptk DEBUG -- MPTK_Env_c::environment() - Load successfully the following Block type: mptk DEBUG -- MPTK_Env_c::environment() - harmonic block. mptk DEBUG -- MPTK_Env_c::environment() - chirp block. mptk DEBUG -- MPTK_Env_c::environment() - mclt block. mptk DEBUG -- MPTK_Env_c::environment() - gabor block. mptk DEBUG -- MPTK_Env_c::environment() - mdst block. mptk DEBUG -- MPTK_Env_c::environment() - constant block. mptk DEBUG -- MPTK_Env_c::environment() - anywavehilbert block. mptk DEBUG -- MPTK_Env_c::environment() - dirac block. mptk DEBUG -- MPTK_Env_c::environment() - nyquist block. mptk DEBUG -- MPTK_Env_c::environment() - mdct block. mptk DEBUG -- MPTK_Env_c::environment() - anywave block. mptk ERROR -- MP_FFT_Interface_c::init_fft_library_config() - fftw wisdom file with path /usr/local/MPTK-0.5.4/bin/default_fftw_wisdom_file doesn't exist . mptk DEBUG -- MPTK_Env_c::environment() - No fftw Plan well formed was found. mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - MPD - MATCHING PURSUIT DECOMPOSITION mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - The command line was: /usr/local/MPTK-0.5.4/bin/mpd -D/home/melot/matlab/Matching_pursuit/default.xml -n1000 -Etempdecay.txt -R100 tempin.wav tempbook.bin tempres.wav mptk INFO -- mpd - End command line. mptk INFO -- mpd - Loading the dictionary... mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk DEBUG -- MP_Dict_c::MP_Dict_c() - Constructing dict... mptk DEBUG -- MP_Dict_c::MP_Dict_c() - Done. mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error while loading the dictionary file [/home/melot/matlab/Matching_pursuit/default.xml]. mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error ID: 7 . mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error description: Error reading Attributes. . mptk ERROR -- MP_Dict_c::init(dictFileName) - The dictionary scanned from file [/home/melot/matlab/Matching_pursuit/default.xml] contains no recognized blocks. mptk DEBUG -- MP_Dict_c::~MP_Dict_c() - Deleting dict... mptk DEBUG -- MP_Dict_c::~MP_Dict_c() - Done. mptk ERROR -- mpd - Failed to create a dictionary from XML file [/home/melot/matlab/Matching_pursuit/default.xml]. ??? Error using ==> bookread Can't open file [tempbook.bin] Error in ==> mpd at 35 varargout{1} = bookread('tempbook.bin'); Error in ==> Mat2MPTKdemo at 2 [B, res, dec]=mpd(y, Fs, 'n', 1000, 'R', 100);%will run mpd with the 'default.xml' dictionary file. |
