Forum: help
Monitor Forum | | RE: changing the dictionary doesn't seem to w [ Reply ] By: Rémi Gribonval on 2008-02-08 10:18 | [forum:8214] |
Dear Clothilde, 1)There is a first issue which comes from the fact that the MPTK_CONFIG_FILENAME variable is not set, which generates the error message > mptk ERROR -- MPTK_Env_c::get_configuration_file() - Could not find MPTK Env > variable with path to config file. > mptk ERROR -- MPTK_Env_c::load_environnement() - couldn't load the MPTK You can solve it by typing setenv MPTK_CONFIG_FILENAME <foo> where I guess that <foo> should be /usr/local/MPTK-0.5.4/bin/path.xml 2) The second issue comes from the fact that there is no 'default.xml' dictionary in the standard MPTK release, however there should be a file /usr/local/MPTK-0.5.4/bin/reference/dictionary/dic_gabor_two_scales.xml Here is what you could try, and let us know if it works: a) duplicate this file to /usr/local/MPTK-0.5.4/bin/reference/dictionary/default.xml b) launch the InstallMat2MPTK script again and provide as Dict Path '/usr/local/MPTK-0.5.4/bin/reference/dictionary' I hope this works. If it does we will probably include the default.xml dictionary in a future release with the appropriate help. Cheers, Remi. |
| changing the dictionary doesn't seem to work [ Reply ] By: Clothilde Melot on 2008-02-08 09:57 | [forum:8213] |
Hello I started again to work on the MPTK toolbox and I still have a problem with the default dictionary. I change the path for the dictionary /path_to_sources/src/tests/signals/ (there is only one default.xml file) It seems to me that I have done what you said I should do and it is still not working. Could you help me ? Do I have to change the path for the dictionary again ? Which path should I choose ? thank you very much by advance with best Clothilde InstallMat2MPTK Enter MPTK Path ['/usr/local/bin/']: ['/usr/local/MPTK-0.5.4/bin/'] Enter Dictionaries Path ['/home/melot/matlab/Matching_pursuit/Dict/']: ['/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/'] >> Mat2MPTKdemo mptk DEBUG -- MP_Msg_Server_c -- Entering the messaging server constructor. mptk DEBUG -- MP_Msg_Server_c -- Exiting the messaging server constructor. mptk DEBUG -- mpd - switch -D : optarg is [/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml]. mptk DEBUG -- mpd - Read dictionary file name [/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml]. mptk DEBUG -- mpd - switch -n : optarg is [1000]. mptk DEBUG -- mpd - Read numIter [1000]. mptk DEBUG -- mpd - switch -E : optarg is [tempdecay.txt]. mptk DEBUG -- mpd - Read decay file name [tempdecay.txt]. mptk DEBUG -- mpd - switch -R : optarg is [100]. mptk DEBUG -- mpd - Read report hit [100]. mptk DEBUG -- mpd - When exiting getopt, optind is [5]. mptk DEBUG -- mpd - (argc is [8].) mptk DEBUG -- mpd - Read sound file name [tempin.wav]. mptk DEBUG -- mpd - Read book file name [tempbook.bin]. mptk DEBUG -- mpd - Read residual file name [tempres.wav]. mptk ERROR -- MPTK_Env_c::get_configuration_file() - Could not find MPTK Env variable with path to config file. mptk ERROR -- MPTK_Env_c::load_environnement() - couldn't load the MPTK environmentmptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - MPD - MATCHING PURSUIT DECOMPOSITION mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - The command line was: /usr/local/MPTK-0.5.4/bin/mpd -D/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml -n1000 -Etempdecay.txt -R100 tempin.wav tempbook.bin tempres.wav mptk INFO -- mpd - End command line. mptk INFO -- mpd - Loading the dictionary... mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk DEBUG -- MP_Dict_c::MP_Dict_c() - Constructing dict... mptk DEBUG -- MP_Dict_c::MP_Dict_c() - Done. mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error while loading the dictionary file [/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml]. mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error ID: 7 . mptk ERROR -- MP_Dict_c::load_xml_file(const char* fName) - Error description: Error reading Attributes. . mptk ERROR -- MP_Dict_c::init(dictFileName) - The dictionary scanned from file [/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml] contains no recognized blocks. mptk DEBUG -- MP_Dict_c::~MP_Dict_c() - Deleting dict... mptk DEBUG -- MP_Dict_c::~MP_Dict_c() - Done. mptk ERROR -- mpd - Failed to create a dictionary from XML file [/home/melot/matlab/Matching_pursuit/path_to_sources/src/tests/signals/default.xml]. ??? Error using ==> bookread Can't open file [tempbook.bin] Error in ==> mpd at 35 varargout{1} = bookread('tempbook.bin'); Error in ==> Mat2MPTKdemo at 2 [B, res, dec]=mpd(y, Fs, 'n', 1000, 'R', 100);%will run mpd with the 'default.xml' dictionary file. |
