Forum: help
Monitor Forum | | RE: changing the dictionary ? [ Reply ] By: Benjamin Roy on 2008-02-05 11:06 | [forum:7891] |
Hello, You may change the dictionary in order to decompose successfuly some wave... There is two default dictionaries in the MPTK source package: path_to_sources/src/tests/signals/dico_test.xml or path_to_sources/reference/dictionary/dic_gabor_two_scales.xml Regards |
| changing the dictionary ? [ Reply ] By: Clothilde Melot on 2008-02-05 09:35 | [forum:7878] |
Thank you very much for this answer. The point is that I am using the default dictionnary in the Matlab interface package. Should I try with another dictionary ? thank you once again with best |
