Forum: help
Monitor Forum | | RE: Difficulty installing MPTK-0.5.4 on Mac O [ Reply ] By: Benjamin Roy on 2008-01-04 09:42 | [forum:6539] |
Hello, It's well konwn issue on OS X when try to build application from LINUX according to: http://lists.apple.com/archives/Unix-porting/2006/May/msg00073.html The remedy is to link using g++ instead of gcc or ld.According to CMake documentation, once the compiler is picked, you can not change it. If you want g++ as compiler, you can do this in a a clean build tree, before using cmake command to create the build system and compile as usual: export CXX=g++ cmake ~/foo Hope it will help, thanks for your interest in MPTK. |
| Difficulty installing MPTK-0.5.4 on Mac OS X [ Reply ] By: Ryan Canolty on 2008-01-04 01:21 | [forum:6531] |
Hello, I have been using the MPTK Windows executable to decompose electrocorticography data and have found it very promising. Thanks to everyone for making this software happen! I would like to compile it on our MacPro (2 dual-core Intel Xeon processors running OS 10.4.11) but am running into some problems. After using the make command I get the following: [ 1%] Built target make_regression_constants [ 1%] Built target mpcat-executable [ 2%] Built target mptk-lib-source [ 2%] Built target dsp_windows-lib-source [ 3%] Built target dsp_windows [ 3%] Built target tinyxml-lib-source [ 6%] Built target tinyxml Linking CXX shared library ../../lib/libmptk.dylib ld: Undefined symbols: __Unwind_Resume /usr/bin/libtool: internal link edit command failed make[2]: *** [lib/libmptk.dylib] Error 1 make[1]: *** [src/libmptk/CMakeFiles/mptk.dir/all] Error 2 make: *** [all] Error 2 The 'Linking CXX' is highlighted in color. I am mainly a MATLAB users and am not used to troubleshooting compilation problems; any tips or ideas? Thanks, Ryan Canolty |
