Forum: help
Monitor Forum | | GettingStarted [ Reply ] By: Frederik Schmidt on 2020-03-02 10:42 | [forum:153478] |
Hi, I'm new here and just installed the MPTK with the User Manual. To test MPTK, I ran GettingStarted. However, Matlab crashes when I press the Enter key after the first query in the Command window. With the help of debugging, I found out that the program crashes after line 100 in the "GettingStarted" function. --> mptkInfo = getmptkinfo; In addition, the if query in line 25 results in a logical 0. That is not so wanted, is it? --> if isempty(getenv('MPTK_CONFIG_FILENAME')) Does anyone know what the problem could be? I only use the following code: clc, clear, close all addpath('C:\Program Files (x86)\MPTK\mptk\matlab') cd('C:\Program Files (x86)\MPTK\mptk\matlab'); GettingStarted The command window shows the following output until the crash: ----------------------------- Welcome to MPTK within Matlab ----------------------------- (press enter to continue) ... -------------------------- Getting MPTK informations -------------------------- I also have attached the crash report. I hope you can help me. |
