Forum: help
Monitor Forum | | RE: Error using getmptkinfo Aborting help [ Reply ] By: Rémi Gribonval on 2013-11-28 10:47 | [forum:148006] |
Hi, It may help if you include a copy of the file '/Users/martinagehwolf/Documents/MATLAB/freshMPTK/MPTK-Source-0.7.0/mptk/path.xml' as well as the list of files in '/Users/martinagehwolf/Documents/MATLAB/freshMPTK/MPTK-Source-0.7.0/lib' and the value of the 'MPTK_CONFIG_FILENAME' environment variable. All the best, Remi. |
| Error using getmptkinfo Aborting help [ Reply ] By: Martina Gehwolf on 2013-11-27 18:15 | [forum:148004] |
Hello, I have installed the mptk toolkit, libsndfile, fftw, Xcode(inc. the Package maker and command line tools), Cmake and I use MATLAB_R2011b. I have had from the beginning a problem with the line 100 and the function getmptkinfo (which is written in cpp) however I have got the getmptkinfo.mexmaci64 in the path. I am running a OS X Lion 10.8 and have downloaded the MPTK-Source-0.7.0, libsndfile-1.0.25 and the fftw-3.3.3 Please help. Below is the command window output when running GettingStarted. If you need any more clarifications please let me know… >> GettingStarted ----------------------------- Welcome to MPTK within Matlab ----------------------------- (press enter to continue) ... -------------------------- Getting MPTK informations -------------------------- mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=dll_directory in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=fftw_wisdomfile in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=reference in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=tmp in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultDict in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveDict in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveTable in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveTableData in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveResult1 in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveResult2 in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultAnyWaveResult3 in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultMixer in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=defaultDictList in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=exampleBook in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=exampleSignal in config file mptk WARNING -- MPTK_Env_c::load_environment() - Two path variable with the same name=exampleStereoSignal in config file mptk ERROR -- MPTK_Env_c::load_environment() - No block type was loaded, even though plugins were found in the dll_directory '/Users/martinagehwolf/Documents/MATLAB/freshMPTK/MPTK-Source-0.7.0/lib' specified by the configuration file '/Users/martinagehwolf/Documents/MATLAB/freshMPTK/MPTK-Source-0.7.0/mptk/path.xml' mptk INFO -- - The most common reason is a configuration file which does not match the installed version of MPTK getmptkinfo error -- could not load the MPTK environment. The most common reason is a missing or erroneous MPTK_CONFIG_FILENAME variable. This environment variable can be set by typing 'setenv('MPTK_CONFIG_FILENAME','<path to configuration file.xml>') from the Matlab command line Error using getmptkinfo Aborting Error in GettingStarted (line 100) mptkInfo = getmptkinfo; |
