Forum: help
Monitor Forum | | RE: MPTK installation problem on Fedora 19 [ Reply ] By: Adele Fusco on 2013-10-28 10:10 | [forum:147933] |
Hi Dan, thank you for your prompt reply. I tried the command you suggested, but unfortunately it does not work. I tried to install using rpm with --nodepts optiona, and apparently it works. But when I run GettingStarded.m code from matlab, it said Undefined function or variable 'getmptkinfo'. Error in GettingStarted (line 100) mptkInfo = getmptkinfo; I thank you for the time you give me. Regards Adele |
| RE: MPTK installation problem on Fedora 19 [ Reply ] By: Dan Stowell on 2013-10-28 09:51 | [forum:147929] |
Is it possible that you need to run sudo ldconfig on your system before it will notice the new library? |
| MPTK installation problem on Fedora 19 [ Reply ] By: Adele Fusco on 2013-10-28 06:16 | [forum:147927] |
Hi all, I have problem installing mptk on Fedora 19 (OS 64 bit ) rpm -U MPTK-binary-0.7.0-x86_64-Linux.rpm errore: Dipendenze fallite: libmptk.so()(64bit) necessario a mptk-0.7.0-1.x86_64 Said that 'dependencies failed' because libmptk.so()(64bit) is necessary to mptk-0.7.0-1.x86_64. libmptk.so is installed in /usr/lib/ I create also a symbolic link into /usr/lib64/ directory to this file, but it does not work. libsndfile has been installed as well as fftw. May someone give me an hint? thank you Adele |
