Forum: help
Monitor Forum | | RE: Installation From Sources: pb with linking libraries lsndfile and lfftw3 [ Reply ] By: Habonneau Jérôme on 2013-07-03 06:44 | [forum:120989] |
Hi, At the end, I ended up building a 64 bit version of the mptk library. It works fine now. Thank you, Jerome |
| RE: Installation From Sources: pb with linking libraries lsndfile and lfftw3 [ Reply ] By: Habonneau Jérôme on 2013-07-02 14:22 | [forum:120716] |
Hello Boris, I agree with you. My OS is 64 bits whereas mptk is built as a 32 bits version. I really don't know why, maybe because cmake thinks my matlab software is a 32 bit version. I fixed the problem for lsndfile creating a symbolic link between /usr/lib/i386-linux-gnu/libsndfile.so and libsndfile.so.1.0.25 Concerning libfftw3, i'm looking forward to install fftw as a 32 bits library. Another solution could be to tell cmake to build the mptk projects as a 64 bits version. Thank you for your help, |
| RE: Installation From Sources: pb with linking libraries lsndfile and lfftw3 [ Reply ] By: Habonneau Jérôme on 2013-07-02 14:16 | [forum:120715] |
Hello Boris, I agree with you. I have a 64 bit OS but the mptk project is built with the 32 bits version. (I don't really know why, maybe because cmake recognizes my matlab software as a 32 bit version) I installed this one /usr/lib/libfftw3.a. I'm trying to install the 32 bit version of this library, if it is possible. Concerning -lsndfile, i fixed it creating a symbolic link between /usr/lib/i386-linux-gnu/libsndfile.so.1.0.25 and /usr/lib/i386-linux-gnu/libsndfile.so. Thank you for your help, Jerome |
| RE: Installation From Sources: pb with linking libraries lsndfile and lfftw3 [ Reply ] By: Boris Mailhe on 2013-07-02 14:05 | [forum:120709] |
Hello Jérôme, Is /usr/lib/libfftw3.a the one you installed? For libfftw3, the linker finds that library but refuses to use it. I don't know the reason for this incompatibility. Maybe you are trying to link 32 and 64 bit objects together? Hope it helps, Boris |
| Installation From Sources: pb with linking libraries lsndfile and lfftw3 [ Reply ] By: Habonneau Jérôme on 2013-07-02 13:46 | [forum:120705] |
Hello, I want to install mptk from sources. I have downloaded the sources, extract them and then try to build the project. I have installed the necessary package libsndfile1, and libfftw3. I am using Linux Mint 13 and gcc v 4.4. When I launched make, I got: [ 1%] Built target make_regression_constants [ 2%] Built target md5sum [ 3%] Built target base64 [ 3%] Built target dsp_windows [ 7%] Built target tinyxml Linking CXX shared library ../../lib/libmptk.so /usr/bin/ld: cannot find -lsndfile /usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../libfftw3.a when searching for -lfftw3 /usr/bin/ld: skipping incompatible /usr/lib/libfftw3.a when searching for -lfftw3 /usr/bin/ld: cannot find -lfftw3 collect2: ld returned 1 exit status make[2]: *** [lib/libmptk.so] Error 1 make[1]: *** [src/libmptk/CMakeFiles/mptk.dir/all] Error 2 make: *** [all] Error 2 I'm assuming the library linker does not find the correct libraries libsndfile.so and libfftw3.a . When i launch locate libsndfile.so and libfftw3.a, these libraries are located in my LD_SEARCH_LIBRARY. Do you have any suggestion? Thank you in advance, Best regards, Jerome |
