Forum: help
Monitor Forum | | problem in gettingstarted [ Reply ] By: Mina ami on 2013-04-10 17:25 | [forum:112186] |
I installed the toolbox as it said on the website. but when I run the gettingstarted file, This error comes: Error in GettingStarted (line 100) mptkInfo = getmptkinfo; it says that you should set the path but it does not work again! :(( what should I do? Is the problem with mex file? should I have C compiler installed on my computer? |
