Forum: help
Monitor Forum | | RE: How to build atoms from the book [ Reply ] By: imen said on 2013-02-01 16:36 | [forum:110428] |
| I think I need to use atomrecons.m script but it is indefined !! | |
| How to build atoms from the book [ Reply ] By: imen said on 2013-01-31 18:24 | [forum:110406] |
Hello all; I use MPTK in Matlab. everything has been worked fine but I want have as output a matrix of NxM such that N is the number of samples of atom and M is the number of atoms in the book. Following of this equation: sigrecons = sum( Coef(i) x atom(i)); Ceof(i) is the inner product between risiduel and the best atom ( i.e atom(i)). I extracted Coef(i) by Coefs=sqrt(decay(1:end-1)-decay(2:end)); and for each Coef(i) I search in the book the correspond atom, but i cann't build atoms correctly and thus the sigrecons hasn't the same curve w.r.t original signal curve. Can any one help me please? |
