Forum: help
Monitor Forum | | RE: Creating new dictionaries [ Reply ] By: suresh kumar on 2013-06-03 06:20 | [forum:116343] |
Hi Boris, As you mentioned <windowopt=4.085> how does this 0.805 is related to sampling frq of 16k. |
| RE: Creating new dictionaries [ Reply ] By: Nicolas Vinuesa on 2012-10-22 09:55 | [forum:110177] |
Dear Boris, I have a new problem. In the gammatone function i have to implement the bandwith depends of the central frequency by a ERB function (ERB=24.7 + 0.108*fc). So my function would be something like (for order 4 n=4): g(t)=a*tââ^(n-1)*e^(-2*pi*1.019*ERB)*cos(2*pi*fc*t + phase). I can't see how to make the bandwith b dependant of fc in the dictionary. Thanks a lot! |
| RE: Creating new dictionaries [ Reply ] By: Nicolas Vinuesa on 2012-10-15 09:13 | [forum:110166] |
Thanks a lot Boris!, i had no idea. After i finish and check the results i will see if it works for me. |
| RE: Creating new dictionaries [ Reply ] By: Boris Mailhe on 2012-10-12 17:16 | [forum:110160] |
Hi Nicolas, There is already a gamma window implemented in MPTK so you might not need to code anything. You should be able to get a gammatone block by building a Gabor block with the following tags: <windowtype=gamma> <windowopt=4.085> (for example) The optional parameter contains both the window order (here 4) and bandwidth/10000 (here 0.085 means the bandwidth is 850). For now it seems to assume that the signal is sampled at 16000Hz. Hope it helps, Boris |
| Creating new dictionaries [ Reply ] By: Nicolas Vinuesa on 2012-10-12 15:08 | [forum:110158] |
Dear all, I am new at MPTK so i am still in the process of understanding how it works, but my idea is to implement a decomposition over a gammatone functions basis. So my question is if it is possible to create a new dictionary for a totally different kind of function (as the gammatone). Thanks for your time |
