Forum: help
Monitor Forum | | RE: mptk-0.6.1 install problem [ Reply ] By: Rémi Gribonval on 2012-04-20 08:30 | [forum:109598] |
You are right, the mptk header and libraries were already installed in /usr/local. Remi. |
| RE: mptk-0.6.1 install problem [ Reply ] By: Bob Sturm on 2012-04-20 08:15 | [forum:109597] |
| Is that because you already have the mptk header and libraries installed in /usr/local? It works for me only when they are already in that location. | |
| RE: mptk-0.6.1 install problem [ Reply ] By: Rémi Gribonval on 2012-04-20 08:11 | [forum:109596] |
OK, good to know that the install solves the problem. On my machine I was able to compile with XCode with the following steps > mkdir build-0.6.1 > cd build-0.6.1 > cmake -G Xcode ../tags/mptk-0.6.1 > open MPTK.xcodeproj/ (this opens XCode) -> "Build and Run" everything is compiled (54 out of 54), with 124 warnings no warning about matlab I run Xcode 3.2.6 and cmake 2.8.7 Remi. I don't know how to fix the XCode, but maybe some answers can be found on CMake.org ? Remi. |
| RE: mptk-0.6.1 install problem [ Reply ] By: Bob Sturm on 2012-04-19 13:52 | [forum:109594] |
| It works when I compile from the command line, _and_ install them. However, XCode complains about the matlab utilities since it cannot find libmptk. | |
| RE: mptk-0.6.1 install problem [ Reply ] By: Rémi Gribonval on 2012-04-19 07:43 | [forum:109592] |
Hi Bob, Did you finish the compilation with 'make install' ? If you type 'otool -L /Users/bobs/Aalborg/research/mptk-0.6.1/mptk/matlab/getmptkinfo.mexmaci64' you should get a list of the shared libraries used by this mex file, something like libmptk.dylib (compatibility version 0.0.0, current version 0.0.0) libmptk4matlab.dylib (compatibility version 0.0.0, current version 0.0.0) @rpath/libmx.dylib (compatibility version 0.0.0, current version 0.0.0) @rpath/libmex.dylib (compatibility version 0.0.0, current version 0.0.0) @rpath/libmat.dylib (compatibility version 0.0.0, current version 0.0.0) /usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current version 7.9.0) /usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 830.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 125.2.0) As far as I understand, the fact that libmptk.dylib (and libmptk4matlab.dylib) appear without a full path means that the dynamic loader will look for them in standard system path. So, the problem may be explained if they are not installed in a standard system path such as '/usr/local/lib'. I hope this is the explanation, in which case a 'make install' should solve the problem ... but this sounds too simple, I am sure you have already tried :-\ >Also, when compiling is done I see at the end >"ld: warning: directory not found for option '-L/opt/local/lib'" Just a guess: you probably have no directory called /opt ? This should be harmless. If you comment out the line "SET(POSSIBLE_LIBRARY_PATH_3 "/opt/local" CACHE INTERNAL "")" in the main CMakeLists.txt file, the warning should be fixed. All the best, Remi. |
| mptk-0.6.1 install problem [ Reply ] By: Bob Sturm on 2012-04-18 17:48 | [forum:109590] |
I am having an error with the installation of 0.6.1. Everything compiles fine, and runs fine from the command window. The problem occurs with the MATLAB interface. After installation, I run GettingStarted.m (the one in mptk/matlab/ not install/mptk/matlab/), and it finds the path.xml right (the one in mptk/ not install/), and it sets the MPTK_CONFIG_FILENAME correctly, but I get the following fatal error when it runs getmptkinfo.m: ??? Invalid MEX-file '/Users/bobs/Aalborg/research/mptk-0.6.1/mptk/matlab/getmptkinfo.mexmaci64': dlopen(/Users/bobs/Aalborg/research/mptk-0.6.1/mptk/matlab/getmptkinfo.mexmaci64, 1): Library not loaded: libmptk.dylib Referenced from: /Users/bobs/Aalborg/research/mptk-0.6.1/mptk/matlab/getmptkinfo.mexmaci64 Reason: image not found. Error in ==> GettingStarted at 100 mptkInfo = getmptkinfo; Should be a simple problem with linking in the mex? Also, when compiling is done I see at the end "ld: warning: directory not found for option '-L/opt/local/lib'" |
