Forum: help
Monitor Forum | | RE: "Getting started" documents are access denied! [ Reply ] By: Jules Espiau de Lamaƫstre on 2012-03-15 14:47 | [forum:109467] |
It seems that the problem goes beyond MPTK project. The forge has been upgraded very recently and the documents seem to be unaccessible. We'll inform you as soon as it is fixed. |
| RE: "Getting started" documents are access denied! [ Reply ] By: Dan Stowell on 2012-03-14 14:14 | [forum:109457] |
| Yes - I was logged in when I discovered this | |
| RE: "Getting started" documents are access denied! [ Reply ] By: Jules Espiau de Lamaƫstre on 2012-03-14 14:12 | [forum:109456] |
Dear Dan, Does it happen even when you are logged in on the forge? Best regards, Jules Espiau |
| "Getting started" documents are access denied! [ Reply ] By: Dan Stowell on 2012-03-14 11:42 | [forum:109455] |
Hi - There are two "Getting started" documents here: https://gforge.inria.fr/docman/?group_id=36&view=listfile&dirid=4265 Clicking on either of them results in Permission denied. This project's administrator will have to grant you permission to view this page. :( Please could you fix this? Would like to Get Started! |
