Forum: help
Monitor Forum | | RE: 0.6.1.deb install fails (missing architecture in control file) [ Reply ] By: Dan Stowell on 2012-03-14 12:30 | [forum:109458] |
Boris, thanks - you are correct; however the error persists: % sudo dpkg -i MPTK-binary-0.6.1-x86_64-Linux.deb dpkg: warning: parsing file '/var/lib/dpkg/available' near line 50003 package 'mptk': missing architecture dpkg: warning: parsing file '/var/lib/dpkg/tmp.ci/control' near line 8 package 'mptk': missing architecture dpkg: error processing MPTK-binary-0.6.1-x86_64-Linux.deb (--install): package architecture () does not match system (amd64) Errors were encountered while processing: MPTK-binary-0.6.1-x86_64-Linux.deb zsh: exit 1 sudo dpkg -i MPTK-binary-0.6.1-x86_64-Linux.deb |
| RE: 0.6.1.deb install fails (missing architecture in control file) [ Reply ] By: Boris Mailhe on 2012-03-14 11:49 | [forum:109454] |
Hi Dan, Are you not trying to install the 32 bit binaries on a 64 bit machine? You should try the x86_64 binaries instead. Hope it helps, Boris |
| 0.6.1.deb install fails (missing architecture in control file) [ Reply ] By: Dan Stowell on 2012-03-14 11:23 | [forum:109453] |
Hi - got the following error trying to install on ubuntu 11.10 64bit: % sudo dpkg -i MPTK-binary-0.6.1-i386-Linux.deb dpkg: warning: parsing file '/var/lib/dpkg/available' near line 49981 package 'mptk': missing architecture dpkg: warning: parsing file '/var/lib/dpkg/tmp.ci/control' near line 8 package 'mptk': missing architecture dpkg: error processing MPTK-binary-0.6.1-i386-Linux.deb (--install): package architecture () does not match system (amd64) Errors were encountered while processing: MPTK-binary-0.6.1-i386-Linux.deb zsh: exit 1 sudo dpkg -i MPTK-binary-0.6.1-i386-Linux.deb |
