Forum: help
Monitor Forum | | RE: MPTK Instal. Vista, CMake Error, Set Path issue [ Reply ] By: Andrew McLeod on 2013-02-14 13:10 | [forum:110493] |
| I think you posted that in the wrong thread... | |
| RE: MPTK Instal. Vista, CMake Error, Set Path issue [ Reply ] By: imen said on 2013-02-14 08:06 | [forum:110491] |
Yes I find a solution and I fell into another problem :) Jeff, MPTK forum member, helped me. If you use a gabor dictionnary, you should use the following equation to buil atoms. atom = amp* window * (1/normalise window) * cos( 2 * pi* freq * t + phase) t= 0: l , l= scale. this discution should be useful https://gforge.inria.fr/forum/forum.php?thread_id=23980&forum_id=109 -------------------------------- size =l; % l: scale Function [ window ] = Gauss( size ) winVals = zeros(1,size); optional = 0.02; optional = 1/(2*optional*(size+1)*(size+1)); counter = 1; for ii=0:floor(size/2)-1 kk = ii - (size-1)/2; winVals(counter) = exp(-kk.^2*optional); winVals(size - counter + 1) = exp(-kk.^2*optional); counter = counter + 1; end |
| RE: MPTK Instal. Vista, CMake Error, Set Path issue [ Reply ] By: Andrew McLeod on 2013-02-14 03:21 | [forum:110490] |
| Did you ever find a solution to this? I'm on vista as well and having the same problem | |
| MPTK Instal. Vista, CMake Error, Set Path issue [ Reply ] By: carlo teh on 2012-02-21 15:48 | [forum:109302] |
Hey I have tried installing MPTK on couple of computers and seems that I run into problems each time. I downloaded the MPTK-Source-0.6.1 file, unzipped it on Desktop, Have an output file on Desktop for the build. When I run Cmake it gives me an error of: 1) Matlab MEX compiler is not found and asks me to turn ON the BUILD_MATLAB_MEX_FILES 2)MATLAB_ENG_LIBRARY NOT FOUND 3)MATLAB_INCLUDE-DIR NOT FOUND 4)MATLAB_MEX_COMPILER NOT FOUND 5)MATLB_ROOT NOT FOUND 6)MPTK_GP_ATOM_H NOT FOUND 7)MPTK_MP_POSITION_H NOT FOUND I need some asap help, as I am in my final stages of research and need a comparison of my program with the MPTK tool box. I much appreciate anyone's help. |
