Forum: help
Monitor Forum | | RE: mptk install problem! [ Reply ] By: hanane musavi on 2016-02-16 19:51 | [forum:150278] |
Hi Ronan I have the same problem as vicky and there is no attachment please upload it again thanks a lot |
| RE: mptk install problem! [ Reply ] By: xing vicky on 2011-12-01 06:25 | [forum:108585] |
Dear Ronan: I installed the packages again following your suggestion and everything seems to be working now. Thank you very much! Vicky |
| RE: mptk install problem! [ Reply ] By: Ronan Le Boulch on 2011-11-30 15:21 | [forum:108576] |
Bonjour Vicky.... I think i have founded the problem ! Youhou In fact, i uploaded a "debug" package instead of a "release" one. Try downloading and installing again and it should work. Give me feedback please. Ronan |
| RE: mptk install problem! [ Reply ] By: xing vicky on 2011-11-30 02:48 | [forum:108569] |
Dear Ronan: Thank you for you help,but the problem still existed.My procedure was the same with you!I uploaded an attachment which included the interface when i run the matlab. I guess it can help you figure out the problem! Thanks again! vicky |
| RE: mptk install problem! [ Reply ] By: Ronan Le Boulch on 2011-11-28 14:53 | [forum:108543] |
Dear Vicky, I tried to simulate your problem using a Windows XP and Matlab 2011b (2011a would not install) but i guess if it works with 2011b it should work also with 2011a...) Here is my procedure : 1) I installed the binary MPTK i386 release 2) I configured the MPTK_CONFIG_FILENAME as a new permanent environment variable 3) I Launched Matlab 4) I get into the C:\Program files\MPTK\mptk\matlab\ path using "cd ..." or clicking on path selection 5) I launch GettingStarted and it works fine Let me know if this problem persist Ronan |
| mptk install problem! [ Reply ] By: xing vicky on 2011-11-25 05:26 | [forum:108525] |
I have installed the MPTK-binary-0[1].6.0-i386-Windows.exe ,and I'm having the following problem: when I run GettingStarted.m I get the following error: Invalid MEX-file 'C:\Program files\MPTK\mptk\matlab\getmptkinfo.mexw32': Error in ==> GettingStarted at 110 mptkInfo = getmptkinfo; which I guess means that matlab is not running the corresponding getmptkinfo.mexmaci function. My configuration is as follows: Microsoft Windows XP matlab R2011a Thank you for your assistance, Vicky. |
