Forum: help
Monitor Forum | | RE: Installation [ Reply ] By: Ronan Le Boulch on 2011-06-16 07:51 | [forum:107332] |
Hi Anirban, There have been several changes to the file locations in the 0.5.7 version. The path.xml file is now located under the INSTALL_PREFIX/mptk/ directory and the plugins are under the INSTALL_PREFIX/mptk/plugins/ directory. Hope it helps, Ronan |
| Installation [ Reply ] By: Anirban Chatterjee on 2011-06-15 20:48 | [forum:107330] |
Hi I have installed the mptk 5.9 on windows xp. Is the path.xml supposed to be in the bin folder? I didnt find it there. However,I did find it in the mptk subfolder. I copied it to the bin and ran a setenvironment command to which, the terminal echoed a "path does not exist" error. I also ran through the path.xml and found mention of a "default_fftw_wisdom_file" in mptk subfolder.. and was surprised to see this file does not exist in the subfolder... Please help |
