Forum: help
Monitor Forum | | Multichannel behavior of MP [ Reply ] By: Matthias Wacker on 2011-05-24 09:55 | [forum:107155] |
Hi all, i am working the the mptk library in c++. And I wonder about the multichannel behaviour of the algorithm: If i see this correctly, the way it actually (or is it just a default setting?) work with multiple signal channels is different from applying the algorithm to each channel individually. Is there an option or a flag that does the search of atoms for each channel separately and finally combines the t-f planes instead of computing and substracting one atom at a time from all channels? Best regards Matthias |
