Forum: help
Monitor Forum | | RE: Signal reconstruction [ Reply ] By: Ronan Le Boulch on 2011-05-16 08:59 | [forum:107106] |
Mathew, We are currently working to resolve this problem but it could take a while ! The solution of your problem is MPTK 0.5.8.... In my opinion there are 2 ways to resolve it : 1) Use MPTK 0.5.8 with a windows 32 bits system ! (WORKS FOR SURE) 2) Force Matlab installation to 32 bits and use MPTK 0.5.8 (WORKS PROBABLY) |
| Signal reconstruction [ Reply ] By: mathew mathew on 2011-05-12 14:48 | [forum:107092] |
Sir, But on using the command mprecons instead like sig_rec = mprecons(book); i m getting the following error. ------------------------------------------------------------------------ Segmentation violation detected at Thu May 12 20:13:50 2011 ------------------------------------------------------------------------ Configuration: MATLAB Version: 7.6.0.324 (R2008a) MATLAB License: 161051 Operating System: Microsoft Windows Vista Window System: Version 6.1 (Build 7600) Processor ID: x86 Family 6 Model 5 Stepping 2, GenuineIntel Virtual Machine: Java 1.6.0 with Sun Microsystems Inc. Java HotSpot(TM) Client VM mixed mode Default Encoding: windows-1252 Fault Count: 1 Register State: EAX = 1d6be860 EBX = 1d6be860 ECX = 00000009 EDX = 00000000 ESI = 00000000 EDI = 1b19cfa8 EBP = 00d3df00 ESP = 00d3deb8 EIP = 04ca16a8 FLG = 00210246 Stack Trace: [0] MDCT_ATOM.dll:0x04ca16a8(0, 0x1b19cfa8, 0x1b19cfa8, 0x1d821a98) This error was detected while a MEX-file was running. If the MEX-file is not an official MathWorks function, please examine its source code for errors. Please consult the External Interfaces Guide for information on debugging MEX-files. If it is an official MathWorks function, please follow these steps to report this problem to The MathWorks so we have the best chance of correcting it: The next time MATLAB is launched under typical usage, a dialog box will open to help you send the error log to The MathWorks. Alternatively, you can send an e-mail to segv@mathworks.com with the following file attached: C:\Users\Mathew\AppData\Local\Temp\matlab_crash_dump.3944 If the problem is reproducible, please submit a Service Request via: http://www.mathworks.com/support/contact_us/ts/help_request_1.html A technical support engineer might contact you with further information. Thank you for your help. MATLAB may attempt to recover, but even if recovery appears successful, we recommend that you save your workspace and restart MATLAB as soon as possible. [Please exit and restart MATLAB]>> Regards, Mathew |
