Forum: help
Monitor Forum | | RE: Reconstruction pblm [ Reply ] By: Rémi Gribonval on 2011-05-12 14:39 | [forum:107091] |
Dear Mathew, -the command for reconstructing a signal from a book from matlab is mprecons, not mpr -mpr is the command provided by Mat2MPTK, a set of Matlab utilities and wrappers for MPTK developed by Pierre Leveau. As far as I know Mat2MPTK is no longer maintained. All the best, Remi. |
| Reconstruction pblm [ Reply ] By: mathew mathew on 2011-05-12 14:20 | [forum:107090] |
Sir, I got a problem while doing matching pursuit in matlab. I have attached matlab code along with. There occurs a problem while using mpr command. clc; clear all; close all; [sig sampleRate] = sigread('glockenspiel.wav'); dict = dictread('C:\Program Files\MPTK\mptk\reference\dictionary\dic_mdct_two_scales.xml'); [book residual decay] = mpdecomp(sig,sampleRate,dict,100); bookwrite(book,'E:\academics\audio coding_mod\exampleBook1.bin'); figure(1); book=bookread('E:\academics\audio coding_mod\exampleBook1.bin'); bookplot(book); figure(2); bookover(book,sig); [sig_rec, Fs] = mpr(book); figure(3); bookover(book,sigrec); The error which i got is given below. ??? Undefined function or variable 'DefPropStruc'. Error in ==> mpr_wrap at 68 PropStruc = Mat2MPTKUpdateOptions(PropStruc, DefPropStruc); Error in ==> mpr at 26 mpr_wrap('tempbook.bin', 'temprec.wav', varargin{:}); Error in ==> example at 15 [sig_rec, Fs] = mpr(book); Window length I used was 256 and 2048. Done making use of MDCT Bases. i have installed MPTK Binary file MPTK-binary-0.5.9-x86_64-Windows. I want to decompose the audio into 2 MDCT Bases of length 256 and 2048 and reconstruct the audio. I didn’t find ‘DefPropStruc’ in Mat2MPTKUpdateOptions. I am an undergraduate engineering student. I don’t know what to do. Please help me. Thanking You, Regards, Mathew. |
