Forum: help
Monitor Forum | | Reconstruction pblm [ Reply ] By: mathew mathew on 2011-04-29 14:16 | [forum:106990] |
Sir, This is with reference to my earlier query on segmentation fault in this forum. Thank you very much for your interest in this question. Is there anyother method to create book and use that to reconstruct original signal avoiding the segmentatiton fault for different audio signals . Because I have seen a paper on 'Union of MDCT Bases for Audio Coding' by Emmanuel Ravelli, Laurent Daudet and Gael Richard making use of mptk toolkit to implement the audio coder. Their they use union of 8 MDCT Bases. The problem is that I am getting segmentation fault while using book other than default book given after creating book and reconstructing using mprecons.m. I used mdct dictionary of 2 bases with length 256 and 2048. Please do help me. Regards, Mathew |
