Forum: help
Monitor Forum | | RE: mptk mex installation problem [ Reply ] By: Daniele Barchiesi on 2011-04-15 12:24 | [forum:106883] |
Hi Ronan, I installed the libraries again following your suggestion and everything seems to be working now. Thank you! Daniele. |
| RE: mptk mex installation problem [ Reply ] By: Ronan Le Boulch on 2011-04-15 11:35 | [forum:106882] |
Hi M Barchiesi, In order to help you i need to have more details about your installation : - Which MPTK did you downloaded ? Source or Binary ? How did you installed the libsndfile and libfftw libraries ? - I suggest to use port command for 32 & 64 bits compatibility : * port install libsndfile +universal * port install fftw-3 +universal If you downloaded the binaries : - I'm guessing that with a 64 bits Snow Leopard and a Matlab R2010b you downloaded the x86_64 ? So you have .mexmaci64 files under the Matlab directory.... Ronan. |
| mptk mex installation problem [ Reply ] By: Daniele Barchiesi on 2011-04-15 10:26 | [forum:106881] |
I'm trying to use the matlab mex implementation of mptk and I'm having the following problem: when I run GettingStarted.m I get the following error: ??? Attempt to execute SCRIPT getmptkinfo as a function: /usr/local/mptk/matlab/getmptkinfo.m Error in ==> GettingStarted at 110 mptkInfo = getmptkinfo; which I guess means that matlab is not running the corresponding getmptkinfo.mexmaci function. My configuration is as follows: Mac OSX 10.6.7 Matlab R2010b fftw, libsndfile and mptk are intalled in various subdirectories of /usr/local/ Thank you for your assistance, Daniele. |
