Forum: help
Monitor Forum | | RE: Details about the atom [ Reply ] By: Ronan Le Boulch on 2011-02-10 08:27 | [forum:106378] |
Hi M Sudhakar, The parameters of the output book in mpdecomp are : - format (double) - numAtoms (double) - numChans (double) - numSamples (double) - sampleRate (double) - index (matrix of double containing) : * 1: Atom number * 2: Type index * 3: Atom index * 4: Atom selected * 4+chan: Atom pos of channel chan) - atom (matrix structure containing) : * Type: Index of the atom (string) * Params (array of the 'atom' structure containing): + Field name + Corresponding value |
| Details about the atom [ Reply ] By: Iswarya Sudhakar on 2011-02-10 06:09 | [forum:106371] |
| In mpdecomp i get the book as one of the output.Iam not aware of the parameters of the book.will u please explain the parameter.....In that i found that one parameter is atom,I wanna know about it in detail....Will u pls help me with it?? | |
