Forum: help
Monitor Forum | | RE: Problems with Mac OS X DMG install MPTK 0.5.8 [ Reply ] By: Bob Sturm on 2010-09-15 15:31 | [forum:105372] |
Excellent! Thank you Boris. I didn't see the mptk directory in there until you mentioned it. -Bob. |
| RE: Problems with Mac OS X DMG install MPTK 0.5.6 [ Reply ] By: Boris Mailhe on 2010-09-15 15:07 | [forum:105371] |
Hi Bob, There have been several changes to the file locations in the 0.5.7 version. The path.xml file is now located under the INSTALL_PREFIX/mptk/ directory and the plugins are under the INSTALL_PREFIX/mptk/plugins/ directory. Try setting your MPTK_CONFIG_FILENAME variable to "/usr/local/mptk/path.xml" to read the new configuration file instead of the old one. You can also delete the out-of-date /usr/local/bin/path.xml. Hope it helps, Boris |
| Problems with Mac OS X DMG install MPTK 0.5.6 [ Reply ] By: Bob Sturm on 2010-09-15 14:04 | [forum:105369] |
I am achieving the following errors when I attempt to run mpd from installing the binaries (background information on my system and other problems I dealt with are here: http://media.aau.dk/CRISSP/2010/09/mptk-058-installation-on-mac-os-x-1064.html#more): mpd -D dic_gabor_two_scales.xml -s 30 TackPnoA#1.wav -E TackPnoA#1_booken.bin TackPnoA#1_book.bin mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC++.6.2.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC++.6.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC++.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC.8.2.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC.8.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libFLAC.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libogg.0.5.3.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libogg.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libogg.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libsndfile.1.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libsndfile.dylib' shared library. mptk ERROR -- MPTK_Env_c::load_environment() - No block type was loaded, even though plugins were found in the dll_directory '/usr/local/lib' specified by the configuration file '/usr/local/bin/path.xml' mptk INFO -- - The most common reason is a configuration file which does not match the installed version of MPTK mptk ERROR -- MPTK_Env_c::load_environment_if_needed() - Could not load the MPTK environment. mptk INFO -- MPTK_Env_c::load_environment_if_needed() - The most common reason is a missing or erroneous MPTK_CONFIG_FILENAME variable. mptk INFO -- MPTK_Env_c::load_environment_if_needed() - The current value is MPTK_CONFIG_FILENAME = [/usr/local/bin/path.xml]. mptk INFO -- - The MPTK environment can be specified either by: mptk INFO -- - a) setting the MPTK_CONFIG_FILENAME environment variable mptk INFO -- - using e.g. 'setenv MPTK_CONFIG_FILENAME <path_to_config_file.xml>' mptk INFO -- - in a shell terminal, or mptk INFO -- - 'setenv('MPTK_CONFIG_FILENAME','<path to configuration file.xml>') mptk INFO -- - from the Matlab command line mptk INFO -- - b) using the -C <path_to_configfile.xml> option in many MPTK command line utilities. ----- Everything seems to be in the right place, and my environment is set Bob-Sturms-iMac:TackPiano bobsturm$ env TERM_PROGRAM=Apple_Terminal TERM=xterm-color SHELL=/bin/bash TMPDIR=/var/folders/Az/Az7IQ4UvEs0JSHbEp50DoU+++TI/-Tmp-/ Apple_PubSub_Socket_Render=/tmp/launch-pnqxMo/Render TERM_PROGRAM_VERSION=273 OLDPWD=/Users/bobsturm/Aalborg/research/201009/data MPTK_CONFIG_FILENAME=/usr/local/bin/path.xml USER=bobsturm COMMAND_MODE=unix2003 SSH_AUTH_SOCK=/tmp/launch-KweIxc/Listeners __CF_USER_TEXT_ENCODING=0x1F5:0:0 PATH=/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/texbin:/usr/X11/bin PWD=/Users/bobsturm/Aalborg/research/201009/data/TackPiano SHLVL=1 HOME=/Users/bobsturm LOGNAME=bobsturm LC_CTYPE=UTF-8 DISPLAY=/tmp/launch-VybgsM/org.x:0 _=/usr/bin/env |
