Forum: help
Monitor Forum | | Bug in the compilation of MPTK 0.5.6 with the Debug flag [ Reply ] By: Fabien Millioz on 2010-03-24 11:34 | [forum:104231] |
Hi, When setting the BUILD_DEBUG flag to 1 with ccmake, the sources does not compile anymore sue to the function "mp_debug_msg": /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mptk_env.cpp: In member function ‘bool MPTK_Env_c::load_environment(const char*)’: /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mptk_env.cpp:247: error: invalid conversion from ‘const char*’ to ‘long unsigned int’ /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mptk_env.cpp:247: error: initializing argument 1 of ‘size_t mp_debug_msg(long unsigned int, const char*, const char*, ...)’ corresponding to: mp_debug_msg(func,"Setting %s=%s\n",nameBufferCstr,pathBufferCstr); /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_atom_plugin.cpp: In member function ‘virtual MP_Real_t MP_Anywave_Atom_Plugin_c::get_field(int, MP_Chan_t)’: /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_atom_plugin.cpp:493: error: no matching function for call to ‘mp_debug_msg(char*&, const char [10])’ /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:433: note: candidates are: size_t mp_debug_msg(long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:453: note: size_t mp_debug_msg(FILE*, long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_atom_plugin.cpp:507: error: no matching function for call to ‘mp_debug_msg(char*&, const char [9])’ /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:433: note: candidates are: size_t mp_debug_msg(long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:453: note: size_t mp_debug_msg(FILE*, long unsigned int, const char*, const char*, ...) corresponding respectively to: mp_debug_msg(func,"Entering\n"); mp_debug_msg(func,"Leaving\n"); /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_hilbert_atom_plugin.cpp: In member function ‘virtual MP_Real_t MP_Anywave_Hilbert_Atom_Plugin_c::get_field(int, int)’: /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_hilbert_atom_plugin.cpp:561: error: no matching function for call to ‘mp_debug_msg(char*&, const char [10])’ /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:433: note: candidates are: size_t mp_debug_msg(long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:453: note: size_t mp_debug_msg(FILE*, long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/plugin/base/anywave_hilbert_atom_plugin.cpp:582: error: no matching function for call to ‘mp_debug_msg(char*&, const char [10])’ /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:433: note: candidates are: size_t mp_debug_msg(long unsigned int, const char*, const char*, ...) /home/fmillioz/MPTK/MPTK-Source-0.5.6/src/libmptk/mp_messaging.h:453: note: size_t mp_debug_msg(FILE*, long unsigned int, const char*, const char*, ...) corresponding respectively to: mp_debug_msg(func,"Entering\n"); mp_debug_msg(func,"Entering\n"); Commenting theses lines enables the compilation. Fabien |
