Forum: help
Monitor Forum | | RE: Problem installing mptk 0.5.6 on mac OSX [ Reply ] By: Jason Hockman on 2009-11-13 14:50 | [forum:103382] |
Just so its documented for future installs, I had the exact issue with OS X 10.6.2 and Cmake 2.6.4. Using the previous stable version (2.4.8) I was able to bypass these errors in the build. It seems 2.6.4 doesn't like to rebuild directories at each pass - something previous versions would do... |
| RE: Problem installing mptk 0.5.6 on mac OSX [ Reply ] By: Sasho Musevic on 2009-05-21 10:35 | [forum:102277] |
Hi Benjamin. Same problem occurres on Ubuntu, if you're running cmake without admin privileges. See thread nr. 102135. Good luck, Sash |
| Problem installing mptk 0.5.6 on mac OSX [ Reply ] By: benjamin sanchez lengeling on 2009-05-21 07:53 | [forum:102276] |
hello, I was following the mptk installation guide for unix and mac osx and installing all required tools and packages (except mptk), while using the cmake ~/foo on the terminal i get these messages: ... -- Looking for C++ include sstream -- Looking for C++ include sstream - found CMake Error at src/CMakeLists.txt:7 (ADD_SUBDIRECTORY): The binary directory /Users/bengt/foo/src/libmptk is already used to build another source directory, so it cannot be used to build source directory /Users/bengt/Desktop/fft/MPTK-Source-0.5.6/src/libmptk Specify a unique binary directory name. CMake Error at src/CMakeLists.txt:10 (ADD_SUBDIRECTORY): The binary directory /Users/bengt/foo/src/libdsp_windows is already used to build another source directory, so it cannot be used to build source directory /Users/bengt/Desktop/fft/MPTK-Source-0.5.6/src/libdsp_windows Specify a unique binary directory name. MEX_COMPILER: = MATLAB_INCLUDE_DIR: include path for mex.h, engine.h = MATLAB_LIBRARIES: required libraries : libmex, etc = MATLAB_MEX_LIBRARY: path to libmex.lib = MATLAB_MX_LIBRARY: path to libmx.lib = MATLAB_ENG_LIBRARY: path to libeng.lib = Warning: Matlab scripts implementing 'poor man' versions of MEX-files will be installed, unless you set BUILD_MATLAB_MEX_FILES to ON. Warning: They may not be maintained and compatible with evolving MPTK data formats. -- Configuring incomplete, errors occurred! any ideas? |
