Forum: help
Monitor Forum | | Adding a class [ Reply ] By: Chris Srinivasa on 2009-05-12 15:19 | [forum:102194] |
| I was wondering how to add my own class of atoms. I noticed that in the source code there is a file HOW_TO_ADD_A_CLASS but when I open it, it is written that this doc is obselete. If so, then can I still use the templates in the plugins section ? I doubt it because I noticed the read() function in the templates assumes that the dictionary parameter format is in the form <par type="freq">200</par> which is not the format for version 0.5.6 since the sample dictionary has the form <param name="freq" value="200">. If this is the case and the document is indeed obselete, then how do I add a new class ? | |
