Forum: help
Monitor Forum | | RE: Multi channel gabor atom dictionary [ Reply ] By: Chris Srinivasa on 2009-05-13 16:12 | [forum:102217] |
| I would like to have 25 gabor atoms each with a different center frequency. For example, the first could have fc=100 Hz, then the second could have fc2=320 Hz, etc. Then, mpd would find the best atom (out of the 25 atoms) which gives me the highest correlation and place a spike in the book at that channel and time. The idea would be that my spikegram (book) in the end would have 25 channels. | |
| RE: Multi channel gabor atom dictionary [ Reply ] By: Boris Mailhe on 2009-05-13 15:33 | [forum:102216] |
Hi, I'm not sure to get what you want to do. Does your signal have 25 channels, or do you want to split it into 25 frequency components? |
| Multi channel gabor atom dictionary [ Reply ] By: Chris Srinivasa on 2009-05-11 19:23 | [forum:102190] |
Hi, I would like to create a dictionary of 25 gabor atoms, each with a different center frequency. Each atom should represent a channel so essentially I would have 25 channels. I know there is a "numchan" parameter for anywave tables but this does not apply in my case. This is the first time I am writting a dictionary in mptk so any help would be appreciated. |
