Forum: help
Monitor Forum | | RE: can't find block when parsing dictionary [ Reply ] By: Sasho Musevic on 2009-05-09 11:07 | [forum:102169] |
Hi! I had similar problems and indeed, the 'make install' doesn't seem to copy/install the block/atom factories, located <mptk_build_dir>/lib/*_ATOM.dylib, <mptk_build_dir>/lib/*_BLOCK.dylib after the build. Basically, "make install" doesn't work properly for me (Mac OS X Leopard) at all. BTW: .dylib is analogous to .so on Linux and .dll on Windows, in case u r wondering. I was trying to get the installation work, but honestly it's just too much hand work. Anyway, a quick solution is this: After running "make", do not do "make install" (it doesn't hurt to do so, tho). Go into <mptk_build_dir>/bin". Now use mpd like this: ./mpd -C path.xml -D dict_file ... It is crucial to use -C switch and force it to use the local path.xml file, located in the <mptk_build_dir>/bin. Experiment with path.xml, located in the installation dir (/usr/local/... somehwere) and try changing the "dll_directory" parameter, if you really want to make the installation work...Good luck though... Hope it helps, Sash |
| RE: can't find block when parsing dictionary [ Reply ] By: Chris Srinivasa on 2009-05-08 20:08 | [forum:102167] |
| Thanks Corey for your help. Unfortunately I tried it and it didn't change anything. | |
| RE: can't find block when parsing dictionary [ Reply ] By: Corey Kereliuk on 2009-05-08 19:28 | [forum:102166] |
Try including the option: -C /mptk-install-path/path.xml |
| can't find block when parsing dictionary [ Reply ] By: Chris Srinivasa on 2009-05-08 19:22 | [forum:102165] |
I am getting the following error when trying to read the default dictionary which comes with mptk: ************************************************** mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. ************************************************** This is the command I typed: ./mpd -D reference/dictionary/dic_gabor_two_scales.xml -n 100 reference/signal/glockenspiel.wav reference/book/test1.bin reference/signal/res1.wav Can someone please help. Could it be a case of an environment variable set badly ? Where is the block factory located ? |
