Forum: help
Monitor Forum | | MPTK 0.5.6 mex files libfftw issues [ Reply ] By: Bertrand Scherrer on 2008-11-28 19:40 | [forum:99029] |
Dear MPTK team, I have built and installed MPTK-0.5.6 on a Mac OS X (10.4.11) machine, following the instructions in the BUILD_MPTK_for_LINUX_OSX.pdf document. I updated my libraries: fftw (3.2), libsndfile (1.0.17). Then I activated the BUILD_MATLAB_MEX_FILES option in ccmake and then ran make and make install. I can find the mex files in /usr/local/matlab/ so the mex compilation seems to have worked. After adding /usr/local/matlab to the path in Matlab I ran the GettingStarted script. I got the following error when the getmptkinfo function was called: ??? Invalid MEX-file '/usr/local/matlab/getmptkinfo.mexmac': dlopen(/usr/local/matlab/getmptkinfo.mexmac, 1): Library not loaded: /opt/local/lib/libfftw3.3.dylib Referenced from: /private/Network/Servers/borges.mt.lan/Volumes/home/scherrer/lib/libmptk.dylib Reason: Incompatible library version: libmptk.dylib requires version 6.0.0 or later, but libfftw3.3.dylib provides version 5.0.0. Error in ==> GettingStarted at 110 mptkInfo = getmptkinfo; It might be a silly question but I am getting a little mixed up with the version numbers that are shown in this error message. In other words, which library does the version 6.0.0 refer to exactly ? Thank you for your help, Bertrand |
