Forum: help
Monitor Forum | | RE: installation on Mac Os [ Reply ] By: Sasho Musevic on 2009-04-15 23:28 | [forum:101996] |
Hello! I have a similar problem, but it seems like it's more persistent. Running cmake, make, sudo make install, I finally get this output: ... Install the project... -- Install configuration: "" -- Installing: /usr/local/bin/reference -- Installing: /usr/local/bin/reference/book -- Up-to-date: /usr/local/bin/reference/book/exampleBook.bin -- Installing: /usr/local/bin/reference/dictionary -- Up-to-date: /usr/local/bin/reference/dictionary/dic_anywave.xml -- Up-to-date: /usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml -- Up-to-date: /usr/local/bin/reference/dictionary/dict-list.txt -- Installing: /usr/local/bin/reference/mixer -- Up-to-date: /usr/local/bin/reference/mixer/mix_58_mixer.txt -- Installing: /usr/local/bin/reference/signal -- Up-to-date: /usr/local/bin/reference/signal/glockenspiel.wav -- Installing: /usr/local/bin/reference/wavetable -- Up-to-date: /usr/local/bin/reference/wavetable/defaultWaveTable.xml -- Up-to-date: /usr/local/bin/reference/wavetable/defaultWaveTableData.bin -- Up-to-date: /usr/local/include/mptk.h -- Installing: /usr/local/lib/libmptk.dylib -- Up-to-date: /usr/local/bin/path.xml -- Installing: /usr/local/lib/libdsp_windows.a -- Installing: /usr/local/lib/libtinyxml.a -- Installing: /usr/local/lib/libmptk.dylib -- Up-to-date: /usr/local/bin/path.xml -- Installing: /usr/local/lib/libdsp_windows.a -- Up-to-date: /usr/local/matlab/README -- Up-to-date: /usr/local/matlab/GettingStarted.m -- Up-to-date: /usr/local/matlab/bookover.m -- Up-to-date: /usr/local/matlab/bookplot.m -- Up-to-date: /usr/local/matlab/mpview.m -- Up-to-date: /usr/local/matlab/bookedit.m -- Up-to-date: /usr/local/matlab/dictcreate_gui.m -- Up-to-date: /usr/local/matlab/MPtoolbaricons.mat -- Up-to-date: /usr/local/matlab/create_synthetic_data.m -- Up-to-date: /usr/local/matlab/savetable.m -- Up-to-date: /usr/local/matlab/dictread.m -- Up-to-date: /usr/local/matlab/dictwrite.m -- Up-to-date: /usr/local/matlab/bookread.m -- Up-to-date: /usr/local/matlab/bookwrite.m -- Installing: /usr/local/bin/mpd -- Installing: /usr/local/bin/mpd_demix -- Installing: /usr/local/bin/mpr -- Installing: /usr/local/bin/mpf -- Installing: /usr/local/bin/mpcat -- Installing: /usr/local/bin/mpview -- Up-to-date: /usr/local/bin/readme.txt All looks fine. Running echo $MPTK_CONFIG_FILENAME returns nothing. Running the following command (from another path location): mpd --verbose -C /usr/local/bin/path.xml -D /usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml -n 5000 ./rich/cello_bowed_string2_G98hz.wav ./rich/cello_bowed_string2_G98hz_1.bin results in the following output: mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse.0.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse.0.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse.2.7.3.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse.2.7.3.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse.2.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse.2.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse_ino64.2.7.3.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse_ino64.2.7.3.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse_ino64.2.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse_ino64.2.dylib Expected in: flat namespace ' . mptk ERROR -- MP_Dll_Manager::load_dll - Error when loading the dll: 'dlopen(/usr/local/lib/libfuse_ino64.dylib, 2): Symbol not found: _iconv Referenced from: /usr/local/lib/libfuse_ino64.dylib Expected in: flat namespace ' . mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libjack.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libjack.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libjackserver.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libjackserver.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs-3g.49.0.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs-3g.49.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs-3g.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs.9.0.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs.9.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libntfs.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libprl_sdk.3.0.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libprl_sdk.3.0.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libprl_sdk.3.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libprl_sdk.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libsndfile.1.dylib' shared library. mptk WARNING -- MP_Dll_Manager::load_dll - No registry symbol in '/usr/local/lib/libsndfile.dylib' shared library. mptk WARNING -- MP_FFT_Interface_c::init_fft_library_config() - fftw wisdom file with path /usr/local/bin/default_fftw_wisdom_file doesn't exist. It will be created. mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - MPD - MATCHING PURSUIT DECOMPOSITION mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - The command line was: mpd --verbose -C /usr/local/bin/path.xml -D /usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml -n 5000 ./rich/cello_bowed_string2_G98hz.wav ./rich/cello_bowed_string2_G98hz_1.bin mptk INFO -- mpd - End command line. mptk INFO -- mpd - Loading the dictionary... mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::init(dictFileName) - The dictionary scanned from file [/usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml] contains no recognized blocks. mptk ERROR -- mpd - Failed to create a dictionary from XML file [/usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml]. s Running the following command (again from location as in previous case): mpd --verbose -D /usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml -n 5000 ./rich/cello_bowed_string2_G98hz.wav ./rich/cello_bowed_string2_G98hz_1.bin Returns this (please note, that -C option is omitted) mptk ERROR -- MPTK_Env_c::get_configuration_file() - Could not find MPTK Env variable with path to config file. mptk ERROR -- MPTK_Env_c::load_environment() - couldn't load the MPTK environment mptk INFO -- - The MPTK environment can be specified either by: mptk INFO -- - a) setting the MPTK_CONFIG_FILENAME environment variable, using e.g. 'setenv MPTK_CONFIG_FILENAME <path_to_config_file.xml>') mptk INFO -- - b) using the -C <path_to_configfile.xml> option in many MPTK command line utilities. mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - MPD - MATCHING PURSUIT DECOMPOSITION mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - The command line was: mpd --verbose -D /usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml -n 5000 ./rich/cello_bowed_string2_G98hz.wav ./rich/cello_bowed_string2_G98hz_1.bin mptk INFO -- mpd - End command line. mptk INFO -- mpd - Loading the dictionary... mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::init(dictFileName) - The dictionary scanned from file [/usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml] contains no recognized blocks. mptk ERROR -- mpd - Failed to create a dictionary from XML file [/usr/local/bin/reference/dictionary/dic_gabor_two_scales.xml]. I'm quite lost, but it seems like a really minor problem, eg: the gabor 'block' is not registered in the block factory or similar. Running: mpd -V returns: mpd -- Matching Pursuit library version 0.5.6 -- mpd $Revision: 1145 $ Thank you in advance, Sash |
| RE: installation on Mac Os [ Reply ] By: Rémi Gribonval on 2008-09-09 14:34 | [forum:98444] |
I don't know if this will be the solution but here is a suggestion which seems to be working on my Mac if you are using csh or tcsh, put the line setenv MPTK_CONFIG_FILENAME <what is needed> in /Users/melot/.cshrc [on bash I suppose you must replace this by export MPTK_CONFIG_FILENAME=<what is needed> in /Users/melot/.bashrc or .bash_profile or .profile] Then, when you launch Matlab, if you type getenv('MPTK_CONFIG_FILENAME') it should return the desired value. The value set in your .cshrc will also be accessible from any application launched from a terminal. Best regards, Remi. |
| RE: installation on Mac Os [ Reply ] By: Clothilde Melot on 2008-09-09 14:19 | [forum:98443] |
Thank you for your anwser. The point is that if I use a terminal, then Matlab is launched in the terminal, and I can no more use the graphic options. I will see if it can be done in a startup file. Thank you once again with best Clothilde |
| RE: installation on Mac Os [ Reply ] By: Boris Mailhe on 2008-09-09 14:12 | [forum:98442] |
Hi, You cannot use all shell commands from inside Matlab, only a few of them. Your environment should be configured before starting Matlab. Have you tried setting the environment in a terminal, then launching Matlab from the same terminal? There must also be a way to have the setenv done automatically at startup, so that you don't have to bother anymore, but I don't know how it works on a mac. You'd better ask a mac user helpdesk about it. Regards, Boris |
| RE: installation on Mac Os [ Reply ] By: Clothilde Melot on 2008-09-09 13:34 | [forum:98441] |
Dear MPTK developpers I have a problem with the setenv command in the Matlab environnement. In fact I don't know why but my version of Matlab doesn't take into account this command. We tried several things including the commands export and system('setenv ...') but it doesn't work. This is a real problem indeed the version 5.6 uses mex versions and I can't get into the Matlab code. Would you have any solution ? Thank you very much by advance with best regards Clothilde |
| RE: installation on Mac Os [ Reply ] By: Clothilde Melot on 2008-09-09 07:52 | [forum:98434] |
Dear Boris Thank you very much for your answer. It did work !! Then the other commands are also ok. Just a little remark: for mpf, the --index=[0:n[ command doesn't work but the -i [0:n[ does. It is the same for all the other classification options. Thank you once again with best regards Clothilde |
| RE: installation on Mac Os [ Reply ] By: Boris Mailhe on 2008-09-08 21:17 | [forum:98432] |
Hi Clothilde, It seems to be our bad there. libmptk.so is loaded before the config file (actually, before doing anything else), so the path to it needs to be set at system level. If you don't want to install MPTK in a system directory (such as /usr/local for example), you can patch that using the DYLD_LIBRARY_PATH environment variable. Check its value using echo $DYLD_LIBRARY_PATH If it's empty, set it to /Users/melot/tmp/MPTK/lib (should be the right path for you) Otherwise, append the path at the end: setenv DYLD_LIBRARY_PATH $DYLD_LIBRARY_PATH:/Users/melot/tmp/MPTK/lib I'm not an OSX specialist, but this should work. Hope it will help, Boris |
| RE: installation on Mac Os [ Reply ] By: Clothilde Melot on 2008-09-08 17:46 | [forum:98431] |
Dear Boris Thank you very much for your answer. I did correct the setenv MPTK_CONFIG_FILENAME and by using the version 0.5.6, I get a new error message which is the following one. Thank you very much by advance [powerbook-g4-15-de-melot:~/tmp] melot% MPTK/bin/mpd -D ../reference/dictionary/dic_gabor_two_scales.xml -n 10 ../reference/signal//glockenspiel.wav booktest.bin dyld: Library not loaded: libmptk.dylib Referenced from: /Users/melot/tmp/MPTK/bin/mpd Reason: image not found Trace/BPT trap |
| RE: installation on Mac Os [ Reply ] By: Boris Mailhe on 2008-09-02 17:00 | [forum:98385] |
Dear Clothilde, There seems to be a problem with your setting of MPTK_CONFIG_FILENAME. The path.xml file is located by default in the bin/ directory, along with mpd. So for you, the right path should be /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/path.xml (the only difference with yours is the last bin/ subdirectory) The warnings at install came from the double inclusion of some build files. They are harmless, though, and cannot be the source of your problems. They will be corrected in the next release. Hope it will help, Boris |
| installation on Mac Os [ Reply ] By: Clothilde Melot on 2008-09-02 15:02 | [forum:98383] |
Dear MPTK developpers I hope you are Ok. I am trying to install MPTK on my Mac OS X and I have several problems with the version 5.5 and I tried with version 5.6 and there are still problems. If you could help me to fix it I would be glad. -version 5.5 I have a directory "build" in MPTK-Source-0.5.5 and I was following the instructions of the document about installation on Mac. When I do the make install then I get at the end CMakeFiles/Makefile2:641: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mpview.dir/clean' CMakeFiles/Makefile2:1471: warning: overriding commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/all' CMakeFiles/Makefile2:653: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/all' CMakeFiles/Makefile2:1479: warning: overriding commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/rule' CMakeFiles/Makefile2:661: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/rule' CMakeFiles/Makefile2:1490: warning: overriding commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/clean' CMakeFiles/Makefile2:672: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mpview-executable.dir/clean' CMakeFiles/Makefile2:1518: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/all' CMakeFiles/Makefile2:700: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/all' CMakeFiles/Makefile2:1530: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/rule' CMakeFiles/Makefile2:712: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/rule' CMakeFiles/Makefile2:1541: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/clean' CMakeFiles/Makefile2:723: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/clean' CMakeFiles/Makefile2:1553: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/all' CMakeFiles/Makefile2:735: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/all' CMakeFiles/Makefile2:1561: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/rule' CMakeFiles/Makefile2:743: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/rule' CMakeFiles/Makefile2:1572: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/clean' CMakeFiles/Makefile2:754: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/clean' Install the project... -- Install configuration: "" -- Installing: /usr/local/bin/mpd CMake Error at src/libmptk/cmake_install.cmake:31 (FILE): file INSTALL cannot copy file "/Users/melot/Documents/matlab/recherche/EEG/Matching_Pursuit/MPTK-Source-0.5.5/build/bin/mpd" to "/usr/local/bin/mpd". Call Stack (most recent call first): cmake_install.cmake:32 (INCLUDE) -then I tried to run the mpd command and I get the following message [powerbook-g4-15-de-melot:Matching_Pursuit/MPTK-Source-0.5.5/build] melot% ls CMakeCache.txt CPackConfig.cmake Makefile cmake_install.cmake doc lib src CMakeFiles CPackSourceConfig.cmake bin config.h include path.xml [powerbook-g4-15-de-melot:Matching_Pursuit/MPTK-Source-0.5.5/build] melot% bin/mpd -D ../reference/dictionary/dic_gabor_two_scales.xml -n 10 ../reference/signal//glockenspiel.wav ../../book.bin mptk ERROR -- MPTK_Env_c::get_configuration_file() - Could not find MPTK Env variable with path to config file. mptk ERROR -- MPTK_Env_c::load_environnement() - couldn't load the MPTK environmentmptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - MPD - MATCHING PURSUIT DECOMPOSITION mptk INFO -- mpd - ------------------------------------ mptk INFO -- mpd - The command line was: bin/mpd -D ../reference/dictionary/dic_gabor_two_scales.xml -n 10 ../reference/signal//glockenspiel.wav ../../book.bin mptk INFO -- mpd - End command line. mptk INFO -- mpd - Loading the dictionary... mptk INFO -- mpd - (In the following, spurious output of dictionary pieces would be a symptom of parsing errors.) mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::create_block(MP_signal_c * setSignal , map<string, PropertiesMap, mp_ltstring> *setPropertyMap) - The gabor block creator is not type is not registred in the block factory. mptk ERROR -- MP_Dict_c::parse_block(TiXmlNode * pParent, map<const char*, PropertiesMap, mp_ltstring> *setPropertyMap) - Cannot create block. mptk ERROR -- MP_Dict_c::parse_xml_file(TiXmlDocument doc) - Error while processing block.processing the remaining block mptk ERROR -- MP_Dict_c::init(dictFileName) - The dictionary scanned from file [../reference/dictionary/dic_gabor_two_scales.xml] contains no recognized blocks. mptk ERROR -- mpd - Failed to create a dictionary from XML file [../reference/dictionary/dic_gabor_two_scales.xml]. -so I tried to install MPTK version 5.6 after make install I get the message CMakeFiles/Makefile2:77: warning: ignoring old commands for target `src/libmptk/CMakeFiles/make_regression_constants.dir/all' CMakeFiles/Makefile2:441: warning: overriding commands for target `src/libmptk/CMakeFiles/make_regression_constants.dir/rule' CMakeFiles/Makefile2:89: warning: ignoring old commands for target `src/libmptk/CMakeFiles/make_regression_constants.dir/rule' CMakeFiles/Makefile2:452: warning: overriding commands for target `src/libmptk/CMakeFiles/make_regression_constants.dir/clean' CMakeFiles/Makefile2:100: warning: ignoring old commands for target `src/libmptk/CMakeFiles/make_regression_constants.dir/clean' CMakeFiles/Makefile2:466: warning: overriding commands for target `src/libmptk/CMakeFiles/mptk.dir/all' CMakeFiles/Makefile2:114: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mptk.dir/all' CMakeFiles/Makefile2:478: warning: overriding commands for target `src/libmptk/CMakeFiles/mptk.dir/rule' CMakeFiles/Makefile2:126: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mptk.dir/rule' CMakeFiles/Makefile2:489: warning: overriding commands for target `src/libmptk/CMakeFiles/mptk.dir/clean' CMakeFiles/Makefile2:137: warning: ignoring old commands for target `src/libmptk/CMakeFiles/mptk.dir/clean' CMakeFiles/Makefile2:517: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/all' CMakeFiles/Makefile2:165: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/all' CMakeFiles/Makefile2:529: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/rule' CMakeFiles/Makefile2:177: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/rule' CMakeFiles/Makefile2:540: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/clean' CMakeFiles/Makefile2:188: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows.dir/clean' CMakeFiles/Makefile2:552: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/all' CMakeFiles/Makefile2:200: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/all' CMakeFiles/Makefile2:560: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/rule' CMakeFiles/Makefile2:208: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/rule' CMakeFiles/Makefile2:571: warning: overriding commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/clean' CMakeFiles/Makefile2:219: warning: ignoring old commands for target `src/libdsp_windows/CMakeFiles/dsp_windows-lib-source.dir/clean' Install the project... -- Install configuration: "" -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/book -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/book/exampleBook.bin -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/dictionary -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/dictionary/dic_anywave.xml -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/dictionary/dic_gabor_two_scales.xml -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/dictionary/dict-list.txt -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/mixer -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/mixer/mix_58_mixer.txt -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/signal -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/signal/glockenspiel.wav -- Installing: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/wavetable -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/wavetable/defaultWaveTable.xml -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/reference/wavetable/defaultWaveTableData.bin -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/include/mptk.h -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/path.xml -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/path.xml -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/README -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/GettingStarted.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/bookover.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/bookplot.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/mpview.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/bookedit.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/dictcreate_gui.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/MPtoolbaricons.mat -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/create_synthetic_data.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/savetable.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/dictread.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/dictwrite.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/bookread.m -- Up-to-date: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/matlab/bookwrite.m -then I set the variables [powerbook-g4-15-de-melot:recherche/Matching_Pursuit/MPTK-0.5.6] melot% setenv MPTK_CONFIG_FILENAME /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/path.xml [powerbook-g4-15-de-melot:recherche/Matching_Pursuit/MPTK-0.5.6] melot% setenv LD_LIBRARY_PATH /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/lib -and then I run mpd Referenced from: /Users/melot/Documents/matlab/recherche/Matching_Pursuit/MPTK-0.5.6/bin/mpd Reason: image not found Trace/BPT trap Let me know if you see what I could do. Thank you so much for your answer with best Clothilde |
