Forum: help
Monitor Forum | | RE: MPD - No library found in... [ Reply ] By: Rémi Gribonval on 2008-08-04 14:09 | [forum:98263] |
Hi Pierre, This is weird. I just checked on my Mac (under 10.5, with CMake 2.4-patch 5, GNU make 3.81) that the default commands listed at the bottom of this mail compile all necessary dylib and put them into MPTK-Source-0.5.6/build/lib/. Which version of MPTK were you using, and which tools did you use to compile ? Xcode or command line tools ? With the command line tools, did you type 'make install' ? Please try to perform a new download+untar+ cmake + ccmake + make and check the relevant error and warning informations during the make process. >On OSX, should not MP_Dll_Manager::load_dll be with dylib rather dll? The name of this function is just an internal convention for MPTK, it could be called MP_DynamicLibrary_Manager::load_library without changing its behaviour. Under OSX it actually deals with dylibs. I hope this helps, Cheers, Warning : Copying the content of the lib/ directory from a previous version of MPTK will not help and will generate unpredictable results. Changing the LD_LIBRARY_PATH will have the same result if you cannot first locate where your libraries have been compiled. Remi. --- The build directory is 'MPTK-Source-0.5.6/build' and the commands used are > pwd /Users/remi/MPTK-Source-0.5.6 > cd build/ > cmake .. [...] > ccmake . [... configure and generate with default settings] > make [....] Then all necessary libraries are built and put in build/lib/. |
| RE: MPD - No library found in... [ Reply ] By: chris layman on 2008-08-01 01:17 | [forum:98247] |
i fixed this by just copying the lib folder from the previous version. but now i have the error: mptk ERROR -- MP_Book_c::print(fname,mask) - Could not open file book.bin to print a book. do i have to create this file book.bin before executing mpd? thanks |
| RE: MPD - No library found in... [ Reply ] By: chris layman on 2008-08-01 00:08 | [forum:98246] |
hey I have the same problem, the lib folder has only plugin-info.txt in it. |
| RE: MPD - No library found in... [ Reply ] By: Pierre Pasquetje on 2008-08-01 00:01 | [forum:98245] |
| Should I set LD_LIBRARY_PATH to another lib folder ? I do not know which one... | |
| MPD - No library found in... [ Reply ] By: Pierre Pasquetje on 2008-07-31 23:56 | [forum:98244] |
Hello, I have compiled everything without any problem for Mac-Intel OS 10.4.11. MPTK is built in the "go" folder. I have set all the paths properly. When I first run MPD, I get the following error : mptk ERROR -- MP_Dll_Manager::load_dll - No library found in '/Applications/mptk/MPTK-Source-0.5.6/go/lib' Indeed, my lib folder only has the "plugin-info.txt" file. Do you know why ? On OSX, should not MP_Dll_Manager::load_dll be with dylib rather dll? Thank you VERY much! |
