Forum: help
Monitor Forum | | RE: shared libraries [ Reply ] By: Benjamin Roy on 2008-07-31 16:19 | [forum:98239] |
Hello, You should try to set the LD_LIBRARY_PATH with the path of the mptk library directory "/usr/local/mptk/lib" for example Cheers, Benjamin. |
| shared libraries [ Reply ] By: Lara Brown on 2008-07-25 18:35 | [forum:98225] |
Hello there, while installing MPTK and after executing cmake, gmake and gmake install I encountered the following error when trying to run (./mpd) from the "/usr/local/mptk" folder: "mpcat: error while loading shared libraries: libmptk.so: cannot open shared object file: No such file or directory" Could someone possibly advise? Thanks a lot in advance. Cheers, Lara |
