Forum: help
Monitor Forum | | RE: Error on Install for wx-widgets gui [ Reply ] By: Justin Donaldson on 2007-02-27 04:22 | [forum:2790] |
| Thanks for the prompt replies. I'm a PhD student in Informatics at Indiana University. Recently I've started getting interested in music and digital signal processing. After reading a recent Nature article on mammalian audio encoding (http://www.nature.com/nature/journal/v439/n7079/full/nature04485.html), I've been digging around trying to find more information on revcor filters, spike encoding, and matching pursuit. I'm in the process of retrieving the revcor cell data from the Boston Ear Lab (http://earlab.bu.edu/databases/collections/revcor/Default.aspx), and will be trying to get this data working with your 'arbitrary convolution' atom option. I'll probably be back with more questions soon, but for now, thanks again! | |
| RE: Error on Install for wx-widgets gui [ Reply ] By: Sacha Krstulovic on 2007-02-23 11:27 | [forum:2778] |
Dear Mr. Donaldson; The community of MPTK users would probably be interested in knowing who you are and what you use MPTK for. Please remember that answers on this forum are made by humans, not by machines. Thanks for your interest in MPTK. Best regards; -* Sacha -*- |
| RE: Error on Install for wx-widgets gui [ Reply ] By: Benjamin Roy on 2007-02-23 09:28 | [forum:2777] |
Hello, MPTK requires at least wx-widget version 2.6.x I suggest you to install a recent version of wx-widget on your system in order to succeed building MPTK with its GUI. I must make mention of the development status of this gui, most of the MPTK package is fairly stable now. However, we haven't reached version 1.0 yet, and particulary gui is still under development. |
| Error on Install for wx-widgets gui [ Reply ] By: Justin Donaldson on 2007-02-23 00:00 | [forum:2776] |
I'm able to compile and run the mptk command line version on OSX10.4, but when I try to include the gui, I get the following error (for make) Using built-in specs. Target: i686-apple-darwin8 Configured with: /private/var/tmp/gcc/gcc-5367.obj~1/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=powerpc-apple-darwin8 --with-arch=nocona --with-tune=generic --program-prefix= --host=i686-apple-darwin8 --target=i686-apple-darwin8 Thread model: posix gcc version 4.0.1 (Apple Computer, Inc. build 5367) /usr/libexec/gcc/i686-apple-darwin8/4.0.1/cc1plus -quiet -v -I/usr/lib/wx/include/mac-unicode-debug-2.5 -I/usr/include/wx-2.5 -I/usr/local/src/MPTK-0.5.3 -I/usr/local/src/mptk -I/usr/local/src/MPTK-0.5.3/src/libmptk -I/usr/local/src/MPTK-0.5.3/src/gui/portaudio_v18_1/pa_common -I/usr/local/src/MPTK-0.5.3/src/gui/portaudio_v18_1/pablio -I/usr/local/src/mptk/src/libmptk -I/usr/local/src/MPTK-0.5.3/src/libdsp_windows -I/usr/lib/wx/include/mac-unicode-debug-2.5 -I/usr/include/wx-2.5 -D__DYNAMIC__ -DNDEBUG -D__WXDEBUG__ -D__WXMAC__ -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -DNO_GCC_PRAGMA /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiApp.cpp -feliminate-unused-debug-symbols -fPIC -quiet -dumpbase MptkGuiApp.cpp -march=nocona -auxbase-strip src/libmptk/CMakeFiles/MptkGuiApp.dir/__/__/__/MPTK-0.5.3/src/gui/MptkGuiApp.o -g -O3 -Wall -version -D__private_extern__=extern -o - | as -arch i386 -force_cpusubtype_ALL -o src/libmptk/CMakeFiles/MptkGuiApp.dir/__/__/__/MPTK-0.5.3/src/gui/MptkGuiApp.o ignoring nonexistent directory "/usr/lib/gcc/i686-apple-darwin8/4.0.1/../../../../i686-apple-darwin8/include" ignoring duplicate directory "/usr/lib/wx/include/mac-unicode-debug-2.5" ignoring duplicate directory "/usr/include/wx-2.5" #include "..." search starts here: #include <...> search starts here: /usr/lib/wx/include/mac-unicode-debug-2.5 /usr/include/wx-2.5 /usr/local/src/MPTK-0.5.3 /usr/local/src/mptk /usr/local/src/MPTK-0.5.3/src/libmptk /usr/local/src/MPTK-0.5.3/src/gui/portaudio_v18_1/pa_common /usr/local/src/MPTK-0.5.3/src/gui/portaudio_v18_1/pablio /usr/local/src/mptk/src/libmptk /usr/local/src/MPTK-0.5.3/src/libdsp_windows /usr/include/c++/4.0.0 /usr/include/c++/4.0.0/i686-apple-darwin8 /usr/include/c++/4.0.0/backward /usr/local/include /usr/lib/gcc/i686-apple-darwin8/4.0.1/include /usr/include /System/Library/Frameworks /Library/Frameworks End of search list. GNU C++ version 4.0.1 (Apple Computer, Inc. build 5367) (i686-apple-darwin8) compiled by GNU C version 4.0.1 (Apple Computer, Inc. build 5367). GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: 97b41042e1f1a6aabc041604e055399a In file included from /usr/include/c++/4.0.0/backward/iostream.h:31, from /usr/local/src/MPTK-0.5.3/src/libmptk/mptk_env.h:46, from /usr/local/src/mptk/src/libmptk/mptk.h:280, from /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiFrame.h:24, from /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiApp.h:4, from /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiApp.cpp:2: /usr/include/c++/4.0.0/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <iostream> instead of the deprecated header <iostream.h>. To disable this warning use -Wno-deprecated. /usr/include/wx-2.5/wx/radiobox.h:32: warning: 'class wxRadioBoxBase' has virtual functions but non-virtual destructor /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiDeleteViewEvent.h: In member function 'virtual wxClassInfo* MptkGuiDeleteViewEvent::GetClassInfo() const': /usr/local/src/MPTK-0.5.3/src/gui/MptkGuiDeleteViewEvent.h:28: error: 'MptkGuiDeleteEvent' has not been declared make[2]: *** [src/libmptk/CMakeFiles/MptkGuiApp.dir/__/__/__/MPTK-0.5.3/src/gui/MptkGuiApp.o] Error 1 make[1]: *** [src/libmptk/CMakeFiles/MptkGuiApp.dir/all] Error 2 make: *** [all] Error 2 |
