Forum: help
Monitor Forum | | RE: install problem about MPTK [ Reply ] By: Sacha Krstulovic on 2005-07-19 13:08 | [forum:292] |
This has been fixed in the bugfix02 release. -*- S -*- |
| install problem about MPTK [ Reply ] By: dont know dont know on 2005-07-08 18:09 | [forum:262] |
hello, it's me ^-^ It's not easy to come in, lol. It seems i am the first one to post the help message. Thanks for SK's letter, but the problem is still on. The version of MPTK i tried to install is 0.4beta. The version of libsndfile i have installed is 1.0.11. And i have tried to use "./configure --with-libsndfile=/usr" My problem is: After i have typed "./configure" commond, an error occured. It said : checking for main in -llibsndfile... no configure: error: LIBSNDFILE library not found -- cannot build libmptk without LIBSNDFILE Then i downloaded the libsndfile(version is 1.0.11) and installed it. But when i run configure again, the same error still occured. I have checked where libsndfile have been installed. Here is the list: /usr/lib: libsndfile.a libsndfile.so libsndfile.so.1.0.11 libsndfile.la libsndfile.so.1 /usr/include: sndfile.h" |
