Forum: help
Monitor Forum | | RE: anywave dictionary [ Reply ] By: Benjamin Roy on 2008-06-09 08:59 | [forum:69954] |
After testing, it seems that the file is not up to date, here is a up to date version of create_synthetic_data(): function create_synthetic_data( savePath, filterLen, filterShift, numFilters, sigLen, numUsedFilters ) % CREATE_SYNTHETICC_DATA create 2 dictionaries and 4 synthetic signals with the atoms % % create_synthetic_data( savePath, filterLen, filterShift, numFilters, sigLen, numUsedFilters ) % % save the workspace, the tables, the signals (wav at 16 khZ) and the dictionaries to the path given in savePath % % filterLen : length of the atoms % filterShift : shift between the atoms in the dictionary % (filterShift == 1 means that the filters are tested at every position) % numFilters : number of atoms in the dictionary % sigLen : length of the signals created % numUsedFilters : number of filters used to create the synthetic signals % set it to a little value to generate sparse signals % % % table 1 : % - numFilters normalized filters % - 1 channel % - size of the filters : filterLen % % table 2 : % - numFilters normalized filters % - 2 channels % - size of the filters : filterLen % % dict 1 : % - uses table 1 % - filterShift = 1 % % dict 2 : % - uses table 2 % - filterShift = 1 % % signal 1 : % - 1 channel % - length = sigLen % - composed of numUsedFilters filters randomly taken in dict 1, with random % amplitude and random location % % signal 2 : % - 2 channels % - length = sigLen % - composed of numUsedFilters filters randomly taken in dict 1, with random % amplitude, and random location, each of which being only on % one of the two channels. % % signal 3 : % - 2 channels % - length = sigLen % - composed of numUsedFilters filters randomly taken in dict 1, with random % amplitude, and random location, each of which being present % at the same place on the two channels, with different % amplitudes % % signal 4 : % - 2 channels % - length = sigLen % - composed of numUsedFilters filters randomly taken in dict 2, with random % amplitude, and random location % %% %% Authors: %% Sylvain Lesage & Sacha Krstulovic & Rémi Gribonval %% Copyright (C) 2005 IRISA %% %% This script is part of the Matching Pursuit Library package, %% distributed under the General Public License. %% %% SVN log: %% $Author: sacha $ %% $Date: 2007-07-13 16:20:18 +0200 (Fri, 13 Jul 2007) $ %% $Revision: 1108 $ %% numChansMono = 1; numChansStereo = 2; % create the dictionaries dict1.numFilters = numFilters; dict1.numChans = numChansMono; dict1.filterLen = filterLen; for filterIdx=1:dict1.numFilters for chanIdx = 1:dict1.numChans tempWave = randn(1,filterLen); dict1.filters(filterIdx).chans(chanIdx).wave = tempWave/sqrt(sum(tempWave*tempWave')); end end nyq = (floor(filterLen/2)*2 == filterLen); nyqIdx = filterLen/2+1; dict3.numFilters = numFilters; dict3.numChans = numChansMono; dict3.filterLen = filterLen; for filterIdx=1:dict3.numFilters for chanIdx = 1:dict3.numChans tempWave = dict1.filters(filterIdx).chans(chanIdx).wave; fTempWave = fft(tempWave); fTempWave(1) = 0; if (nyq) fTempWave(nyqIdx) = 0; end tempWave = ifft(fTempWave); dict3.filters(filterIdx).chans(chanIdx).wave = tempWave/sqrt(sum(tempWave*tempWave')); end end dict2.numFilters = numFilters; dict2.numChans = numChansStereo; dict2.filterLen = filterLen; for filterIdx=1:dict2.numFilters tempSum = 0; for chanIdx = 1:dict2.numChans tempWave = randn(1,filterLen); tempSum = tempSum + tempWave*tempWave'; dict2.filters(filterIdx).chans(chanIdx).wave = tempWave; end tempSum = 1/sqrt(tempSum); for chanIdx = 1:dict2.numChans dict2.filters(filterIdx).chans(chanIdx).wave = dict2.filters(filterIdx).chans(chanIdx).wave * tempSum; end end % create the signals % signal 1 sig1 = zeros(1,sigLen); sig1FiltIdx = randint(1,numUsedFilters,[1 dict1.numFilters]); sig1FiltLoc = randint(1,numUsedFilters,[1 (sigLen-dict1.filterLen+1)]); sig1FiltAmpl = randn(1,numUsedFilters); for filterIdx = 1:numUsedFilters sig1(sig1FiltLoc(filterIdx)+(0:(dict1.filterLen-1))) = dict1.filters(sig1FiltIdx(filterIdx)).chans(1).wave * sig1FiltAmpl(filterIdx); end sig1Factor = 0.95/max(abs(sig1(:))); sig1 = sig1 * sig1Factor; % signal 2 sig2 = zeros(2,sigLen); sig2FiltIdx = randint(1,numUsedFilters,[1 dict1.numFilters]); sig2FiltChanIdx = randint(1,numUsedFilters,[1 2]); sig2FiltLoc = randint(1,numUsedFilters,[1 (sigLen-dict1.filterLen+1)]); sig2FiltAmpl = randn(1,numUsedFilters); for filterIdx = 1:numUsedFilters sig2(sig2FiltChanIdx(filterIdx),sig2FiltLoc(filterIdx)+(0:dict1.filterLen-1)) = dict1.filters(sig2FiltIdx(filterIdx)).chans(1).wave * sig2FiltAmpl(filterIdx); end sig2Factor = 0.95/max(abs(sig2(:))); sig2 = sig2 * sig2Factor; % signal 3 sig3 = zeros(2,sigLen); sig3FiltIdx = randint(1,numUsedFilters,[1 dict1.numFilters]); sig3FiltLoc = randint(1,numUsedFilters,[1 (sigLen-dict1.filterLen+1)]); sig3FiltAmpl = randn(2,numUsedFilters); for filterIdx = 1:numUsedFilters for chanIdx = 1:2 sig3(chanIdx,sig3FiltLoc(filterIdx)+(0:dict1.filterLen-1)) = dict1.filters(sig3FiltIdx(filterIdx)).chans(1).wave * sig3FiltAmpl(chanIdx,filterIdx); end end sig3Factor = 0.95/max(abs(sig3(:))); sig3 = sig3 * sig3Factor; % signal 4 sig4 = zeros(2,sigLen); sig4FiltIdx = randint(1,numUsedFilters,[1 dict2.numFilters]); sig4FiltLoc = randint(1,numUsedFilters,[1 (sigLen-dict2.filterLen+1)]); sig4FiltAmpl = randn(1,numUsedFilters); for filterIdx = 1:numUsedFilters for chanIdx = 1:2 sig4(chanIdx,sig4FiltLoc(filterIdx)+(0:dict2.filterLen-1)) = dict2.filters(sig4FiltIdx(filterIdx)).chans(chanIdx).wave * sig4FiltAmpl(1,filterIdx); end end sig4Factor = 0.95/max(abs(sig4(:))); sig4 = sig4 * sig4Factor; % signal 5 sig5 = randn(1,sigLen); sig5Factor = 0.95/max(abs(sig5(:))); sig5 = sig5 * sig5Factor; % signal 6 sig6 = randn(1,sigLen); sig6Factor = 0.95/max(abs(sig6(:))); sig6 = sig6 * sig6Factor; % saves samplingFreq = 16000; bitNum = 16; % workspace save([savePath '/ANYWAVE_synthetic_data.mat']); % signals wavwrite(sig1',samplingFreq, bitNum, [savePath '/sig1.wav']); wavwrite(sig2',samplingFreq, bitNum, [savePath '/sig2.wav']); wavwrite(sig3',samplingFreq, bitNum, [savePath '/sig3.wav']); wavwrite(sig4',samplingFreq, bitNum, [savePath '/sig4.wav']); wavwrite(sig5',samplingFreq, bitNum, [savePath '/sig5.wav']); wavwrite(sig6',samplingFreq, bitNum, [savePath '/sig6.wav']); % tables savetable( dict1, [savePath '/table1.xml'], [savePath '/table1_data.bin'] ); savetable( dict2, [savePath '/table2.xml'], [savePath '/table2_data.bin'] ) savetable( dict3, [savePath '/table3.xml'], [savePath '/table3_data.bin'] ); % dictionaries fid = fopen( [savePath '/dict1.xml'], 'wt'); fprintf(fid, '<?xml version="1.0" encoding="ISO-8859-1"?>\n'); fprintf(fid, '<dict>\n'); fprintf(fid, '<libVersion>0.5.4</libVersion>\n'); fprintf(fid, '\t<block>\n'); fprintf(fid, '\t<param name="type" value="anywave"/>\n'); fprintf(fid, '\t\t<param name="tableFileName" value="%s"/>\n', [savePath '/table1.xml']); fprintf(fid, '\t\t<param name="windowShift" value="%i"/>\n', filterShift); fprintf(fid, '\t</block>\n'); fprintf(fid, '</dict>'); fclose( fid ); fid = fopen( [savePath '/dict2.xml'], 'wt'); fprintf(fid, '<?xml version="1.0" encoding="ISO-8859-1"?>\n'); fprintf(fid, '<dict>\n'); fprintf(fid, '<libVersion>0.5.4</libVersion>\n'); fprintf(fid, '\t<block>\n'); fprintf(fid, '\t<param name="type" value="anywave"/> \n'); fprintf(fid, '\t\t<param name="tableFileName" value="%s"/>\n', [savePath '/table2.xml']); fprintf(fid, '\t\t<param name="windowShift" value="%i"/>\n', filterShift); fprintf(fid, '\t</block>\n'); fprintf(fid, '</dict>'); fclose( fid ); fid = fopen( [savePath '/dict3.xml'], 'wt'); fprintf(fid, '<?xml version="1.0" encoding="ISO-8859-1"?>\n'); fprintf(fid, '<dict>\n'); fprintf(fid, '<libVersion>0.5.4</libVersion>\n'); fprintf(fid, '\t<block>\n'); fprintf(fid, '\t<param name="type" value="anywave"/> \n'); fprintf(fid, '\t\t<param name="tableFileName" value="%s"/>\n', [savePath '/table3.xml']); fprintf(fid, '\t\t<param name="windowShift" value="%i"/>\n', filterShift); fprintf(fid, '\t</block>\n'); fprintf(fid, '</dict>'); fclose( fid ); fid = fopen( [savePath '/dict3_hilbert.xml'], 'wt'); fprintf(fid, '<?xml version="1.0" encoding="ISO-8859-1"?>\n'); fprintf(fid, '<dict>\n'); fprintf(fid, '<libVersion>0.5.4</libVersion>\n'); fprintf(fid, '\t<block>\n'); fprintf(fid, '\t<param name="type" value="anywavehilbert"/>\n'); fprintf(fid, '\t\t<param name="tableFileName" value="%s"/>\n', [savePath '/table3.xml']); fprintf(fid, '\t\t<param name="windowShift" value="%i"/>\n', filterShift); fprintf(fid, '\t</block>\n'); fprintf(fid, '</dict>'); fclose( fid ); |
| RE: anywave dictionary [ Reply ] By: Benjamin Roy on 2008-06-09 07:45 | [forum:69934] |
Hello, In order to create an example of dictionary including anywave block, you can use the matlab create_synthetic_data() method located in MPTK_sources_dir/src/matlab/scripts. With best. Benjamin. |
| anywave dictionary [ Reply ] By: Clothilde Melot on 2008-06-02 15:12 | [forum:67746] |
Dear developpers We are working on the dictionaries. But we didn't find any example on a dictionary with "anywave" atoms inside. Could you tell us where we could find an example with a table.bin file ? Thank you very much by advanc with best Sandrine and Clothilde |
