GettingStarted | Frederik Schmidt | 0 | 2020-03-02 10:42 |
Crash after GettingStarted | Frederik Schmidt | 0 | 2020-03-02 10:49 |
Gammatone dictionary | bharathi surisetti | 3 | 2018-12-11 12:03 |
Custom waves | Matthew Aidekman | 0 | 2018-11-24 03:06 |
getting started error | rami mo | 0 | 2018-05-06 11:02 |
mp_system.h not found... | Jamie Bullock | 0 | 2017-06-20 11:50 |
No stdout for mpr.exe (version 0.6.1) | David Browne | 1 | 2017-02-03 06:37 |
Matlab Compiled .NET Assemblies causing access violation errors | David Browne | 1 | 2017-01-24 05:39 |
Error while loading the dictionary file [exampleBook.bin] | g b | 0 | 2016-05-06 11:34 |
MPTK anywave questions | Roilhi Ibarra | 0 | 2016-03-18 20:26 |
mptk install problem! | xing vicky | 5 | 2016-02-16 19:51 |
Matlab gets crashed whenever I execute Getstarted.m or my code | bharathi surisetti | 0 | 2016-01-27 02:59 |
Problem matlab install ubuntu | Alejandro Cruz | 4 | 2015-09-24 06:31 |
Building Atoms From the Dictionary | Krish Bala | 0 | 2015-09-23 19:12 |
Heisenberg box | Nicolas Ayroles | 2 | 2014-11-25 19:47 |
MPTK Source on Visual Studio | Krish Bala | 0 | 2015-06-18 16:10 |
Changing the cost function | Branislav Gerazov | 1 | 2014-09-30 16:07 |
mpdecomp help | Krish Bala | 1 | 2014-08-12 09:08 |
Help on mpdecomp | Krish Bala | 0 | 2014-07-30 18:58 |
basic questions: anywavehilbert, nonnegative weights | Graham Coleman | 1 | 2014-06-28 15:22 |
Individual Gabor atoms | Jessica Beltran | 3 | 2014-02-25 19:15 |
Gabor atoms: Dictionaries, parameters, issues | Jessica Beltran | 0 | 2014-02-20 21:25 |
data type | behnaz jahanshahi | 0 | 2014-01-29 09:34 |
Exemples d'utilisation de MPTK. MPTK examples | Christian Guilleminot | 0 | 2014-01-16 19:55 |
Livre du signal et supression d'atomes | Christian Guilleminot | 0 | 2014-01-16 19:50 |
Error using getmptkinfo Aborting help | Martina Gehwolf | 1 | 2013-11-28 10:47 |
MPTK installation problem on Fedora 19 | Adele Fusco | 2 | 2013-10-28 10:10 |
Using MPTK as a library | Bob Sturm | 1 | 2013-08-23 14:18 |
liblib? | Bob Sturm | 1 | 2013-08-23 14:00 |
Installation From Sources: pb with linking libraries lsndfile and lfftw3 | Habonneau Jérôme | 4 | 2013-07-03 06:44 |
Gammatone function | suresh kumar | 0 | 2013-06-10 17:49 |
Creating new dictionaries | Nicolas Vinuesa | 4 | 2013-06-03 06:20 |
problem in gettingstarted | Mina ami | 0 | 2013-04-10 17:25 |
mpr segfault on simple anywave example | Dan Stowell | 0 | 2013-03-14 16:27 |
Anywave, and sliding templates on spectrograms | Dan Stowell | 1 | 2013-03-13 10:57 |
Plotting harmonic MP | Andrew McLeod | 0 | 2013-02-16 19:01 |
Wigner-Ville Distribution | imen said | 1 | 2013-02-15 18:34 |
MPTK Instal. Vista, CMake Error, Set Path issue | carlo teh | 3 | 2013-02-14 13:10 |
How to build atoms from the book | imen said | 1 | 2013-02-01 16:36 |
Applying for another signal. start form GettingStarted.m ?? | Humbang P | 0 | 2013-01-23 09:17 |
Fonction d'onde formantique (FOF) in MPTK | Nicolas Vinuesa | 0 | 2013-01-15 11:08 |
Problem using anywave atoms | Nicolas Vinuesa | 0 | 2013-01-03 10:44 |
Changing the selection step in MP. | Nicolas Vinuesa | 4 | 2012-11-27 13:57 |
MPTK dictionaries | Nicolas Vinuesa | 0 | 2012-11-16 11:19 |
Gabor parameters and xml structure | Andres Perez | 10 | 2012-11-09 15:09 |
Number of basis functions in dictionary | Nicolas Vinuesa | 0 | 2012-10-30 10:32 |
About gabor atoms / gammatone functions. | Nicolas Vinuesa | 0 | 2012-10-24 11:47 |
Time frequency analysis | XINjian li | 2 | 2012-10-12 16:02 |
Time frequency analysis | XINjian li | 0 | 2012-10-02 16:58 |
time_frequency mp | XINjian li | 0 | 2012-10-02 16:39 |
Re: scale parameter of an atom | suresh kumar | 4 | 2012-10-01 13:38 |
Re: scale parameter of an atom | suresh kumar | 0 | 2012-09-26 06:54 |
extraction de fréquence et position temporelle d'atome | Sana Ben Salah | 1 | 2012-09-10 21:04 |
Chirp-fitting example - difficulty with fast chirps | Dan Stowell | 7 | 2012-07-18 21:05 |
Compiled sources: load_environment() fails to retrieve the 3 dll's | Jean-François Baure | 5 | 2012-05-04 11:49 |
mptk-0.6.1 install problem | Bob Sturm | 5 | 2012-04-20 08:30 |
Dictionary Build and Read----URGENT | carlo teh | 1 | 2012-04-18 17:35 |
"Getting started" documents are access denied! | Dan Stowell | 3 | 2012-03-15 14:47 |
0.6.1.deb install fails (missing architecture in control file) | Dan Stowell | 2 | 2012-03-14 12:30 |
Mac build problem, "-single_module" flag | Dan Stowell | 0 | 2012-02-09 15:24 |
tableIdx in anywave block (matlab interface) | Stefan Kersten | 0 | 2012-02-09 14:19 |
atom amp | Sana Ben Salah | 2 | 2011-12-09 16:21 |
Window Opt and atom reconstruction | Faten MINA | 1 | 2011-12-08 16:35 |
Data read off from book file | Anirban Chatterjee | 0 | 2011-06-22 17:50 |
Installation | Anirban Chatterjee | 1 | 2011-06-16 07:51 |
Multichannel behavior of MP | Matthias Wacker | 0 | 2011-05-24 09:55 |
Signal reconstruction | mathew mathew | 1 | 2011-05-16 08:59 |
Reconstruction pblm | mathew mathew | 1 | 2011-05-12 14:39 |
MPD error | mohan m | 1 | 2011-05-11 06:46 |
Reconstruction pblm | mathew mathew | 0 | 2011-04-29 14:16 |
Segmentation fault | mathew mathew | 2 | 2011-04-28 14:13 |
decay | Sana Ben Salah | 2 | 2011-04-21 07:28 |
output sous forme de vecteur de coeffs | Sana Ben Salah | 1 | 2011-04-21 06:43 |
mptk mex installation problem | Daniele Barchiesi | 2 | 2011-04-15 12:24 |
mpview | Robert Reijntjes reyntjesr | 3 | 2011-03-15 12:39 |
retrieving the coefficients | Iswarya Sudhakar | 1 | 2011-03-09 09:13 |
how to retrieve the atoms and the coefficient | Iswarya Sudhakar | 1 | 2011-02-14 14:49 |
Details about the atom | Iswarya Sudhakar | 1 | 2011-02-10 08:27 |
Welcome to MPTK's Help forum | Sacha Krstulovic | 1 | 2011-02-10 06:01 |
compiling mexmaci64 utilities in 0.5.8 | Bob Sturm | 1 | 2010-09-17 06:37 |
Problems with Mac OS X DMG install MPTK 0.5.6 | Bob Sturm | 2 | 2010-09-15 15:31 |
Trouble installing Matlab Mex files on Mac | Emily Stephen | 6 | 2010-04-21 23:27 |
Strange behavior in the chirp block | Fabien Millioz | 0 | 2010-03-24 11:56 |
Documentations not up to date | Fabien Millioz | 0 | 2010-03-24 11:42 |
Bug in the compilation of MPTK 0.5.6 with the Debug flag | Fabien Millioz | 0 | 2010-03-24 11:34 |
Cannot scan atom type | bernhard niedermayer | 0 | 2010-02-04 12:46 |
Problem installing mptk 0.5.6 on mac OSX | benjamin sanchez lengeling | 2 | 2009-11-13 14:50 |
cmake installation error in Linux (Ubuntu) | Chris Srinivasa | 5 | 2009-06-03 15:41 |
Atom correlations in init_parameters() | Chris Srinivasa | 0 | 2009-05-21 18:55 |
make mptk stops at 73% ?? | Chris Srinivasa | 3 | 2009-05-13 16:33 |
Multi channel gabor atom dictionary | Chris Srinivasa | 2 | 2009-05-13 16:12 |
Adding a class | Chris Srinivasa | 0 | 2009-05-12 15:19 |
can't find block when parsing dictionary | Chris Srinivasa | 3 | 2009-05-09 11:07 |
mpd on MacOSX : 'terminate called' | Sasho Musevic | 2 | 2009-04-18 14:31 |
Anywave Dictionary | Corey Kereliuk | 2 | 2009-04-17 15:28 |
installation on Mac Os | Clothilde Melot | 9 | 2009-04-15 23:28 |
Speed | Corey Kereliuk | 1 | 2009-02-02 13:16 |
questions of Gabor Dic. & ICASSP'08 paper | Yi Zhan | 1 | 2009-02-02 08:23 |
Mex File Error | Corey Kereliuk | 1 | 2009-01-26 09:20 |
InstallMat2MPTK's question | Yi Zhan | 1 | 2009-01-08 19:44 |
mpd -dictFILE.txt question? | Yi Zhan | 1 | 2008-12-24 12:42 |
Install questions(Win32), dir/ of fftw,etc. | Yi Zhan | 0 | 2008-12-13 02:40 |
MPTK 0.5.6 mex files libfftw issues | Bertrand Scherrer | 0 | 2008-11-28 19:40 |
bout mptk | sridevi | 0 | 2008-11-09 04:52 |
Building Dictionaries | chris layman | 13 | 2008-11-07 19:51 |
Version and dictionaries | Clothilde Melot | 1 | 2008-10-27 22:46 |
mptk ERROR -- MP_Dll_Manager | chris layman | 2 | 2008-10-27 22:42 |
Edge effects from atoms | Dillion Tan | 0 | 2008-10-14 02:57 |
mpdecomp segfault | aurelien hazan | 2 | 2008-10-09 09:38 |
Book format for mpd and mptk-gui | Dillion Tan | 2 | 2008-10-08 09:30 |
mprecons | chris layman | 4 | 2008-09-17 20:23 |
Mex compiler | chris layman | 23 | 2008-09-03 00:22 |
MPD - No library found in... | Pierre Pasquetje | 4 | 2008-08-04 14:09 |
Ugh!! | chris layman | 5 | 2008-08-04 13:39 |
shared libraries | Lara Brown | 1 | 2008-07-31 16:19 |
Time-frequency maps using mpview | Supratim Ray | 3 | 2008-07-29 20:28 |
Normalization of gabor atoms | Supratim Ray | 3 | 2008-07-21 13:59 |
reading book files | Courtenay Cotton | 1 | 2008-07-16 08:40 |
Using MPTK on winXP laptop | Arjen Knol | 3 | 2008-07-15 11:33 |
Soem questions about MPTK | Supratim Ray | 1 | 2008-07-07 09:16 |
mpf.m | Clothilde Melot | 1 | 2008-07-07 08:49 |
Problem with MEX files | Kaustuv Chatterjee | 2 | 2008-06-20 07:45 |
anywave dictionary | Clothilde Melot | 2 | 2008-06-09 08:59 |
Install on Mac | chris layman | 7 | 2008-05-30 10:02 |
FFTW and MPTK: enable multithreading | Andrew Gardner | 2 | 2008-05-20 18:43 |
description of atoms | Clothilde Melot | 1 | 2008-05-13 13:19 |
MPTK bug report progress? | Aaron McLeran | 1 | 2008-03-13 16:40 |
Port Audio v 1.8.1 | Aaron McLeran | 0 | 2008-03-12 06:23 |
'length' has to be taken instead of 'l' | Clothilde Melot | 0 | 2008-02-19 15:38 |
mpf.m | Clothilde Melot | 0 | 2008-02-19 15:34 |
everything is working ! | Clothilde Melot | 0 | 2008-02-19 08:49 |
mpf -i | Clothilde Melot | 1 | 2008-02-19 07:39 |
several details | Clothilde Melot | 1 | 2008-02-18 11:40 |
it is runing, but where does it go ? | Clothilde Melot | 1 | 2008-02-14 22:30 |
Thank you ! It is computing !!1 | Clothilde Melot | 1 | 2008-02-14 22:25 |
help with MPTK-0.5.4, Windows, Matlab | Andrew Gardner | 1 | 2008-02-14 22:23 |
one step further | Clothilde Melot | 1 | 2008-02-14 11:07 |
results of the command lines | Clothilde Melot | 1 | 2008-02-08 14:10 |
fftwisdom file seems to appear again ! | Clothilde Melot | 1 | 2008-02-08 11:49 |
changing the dictionary doesn't seem to work | Clothilde Melot | 1 | 2008-02-08 10:18 |
changing the dictionary ? | Clothilde Melot | 1 | 2008-02-05 11:06 |
installing MPTK and using the matlab interfac | Clothilde Melot | 1 | 2008-02-04 16:42 |
Difficulty installing MPTK-0.5.4 on Mac OS X | Ryan Canolty | 1 | 2008-01-04 09:42 |
The gabor block is not registred in the atom | Antoine Liutkus | 6 | 2007-12-06 17:08 |
MPTK Wavelet | Frédéric CAUDAL | 1 | 2007-11-23 15:48 |
About the selecting of atoms | Ji Haiyan | 0 | 2007-07-24 07:00 |
win32 question | Russell Fischer | 5 | 2007-07-11 01:16 |
plotting gabor atoms | Maria Jafari | 1 | 2007-06-20 07:20 |
Matalb Code | Nakul Choudhary | 2 | 2007-05-30 10:43 |
build MPTK using CMAKE | Ji Haiyan | 3 | 2007-05-22 13:03 |
Win32 exe | Hassan Lahdili | 4 | 2007-05-07 18:18 |
Feedback | Ji Haiyan | 12 | 2007-04-20 08:38 |
Error on Install for wx-widgets gui | Justin Donaldson | 3 | 2007-02-27 04:22 |
Win32 executable | Kaustuv Chatterjee | 9 | 2007-02-24 15:13 |
Question about "mpd_demix" | Namgook Cho | 3 | 2007-02-02 09:25 |
No Of Samples | Kamil Adiloglu | 4 | 2007-01-31 11:18 |
time-frequency pixmap fill it | Kamil Adiloglu | 6 | 2007-01-05 13:40 |
install problem about MPTK | dont know dont know | 1 | 2005-07-19 13:08 |
